Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
When attempting to start up computer monitor reads invalid system disk replace and restart
    President:
  • 2,653 Answers
Hopefully you've got either a floppy or cd in the computer tray. Make sure it's empty then reboot. Also make sure you don't have any usb drives plugged in.
Let me know what happens.
Posted on Dec 31, 2010
My MAC G5 disk utility repair cannot repair selected items
use disk utilty from system disk by restarting computer holding down c key then go into disk utility and try it.
Jan 21, 2014 | Apple Power Mac G5 Desktop
The last attempt to restart the system from its previous location failed. attempt to restart again?
it wont boot , right?
if you have no restore points all this is useless.
use your windoz, install disk , boot to it. then pick repair.
state all symptoms, not just , last attempt question.
you can click that 100 times, and you get the same results.
Sep 30, 2013 | ViewSonic E771 17" CRT Monitor
Hard disk cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
My desktop computer won't turn on it just keeps blinking orange.
A computer that won't start can be both alarming and infuriating, especially if you're on a deadline or you haven't been backing up all your data (like we all tend to do). Don't panic, though-this problem often has a simple solution.
1. If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2. If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3. If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4. If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5. If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6. If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7. If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it.
You can check it here as well:
The minute your computer's hard disk starts to act flaky, make sure you have an up-to-date backup. Then you can do some simple diagnostics and repairs. Both Windows and Mac OS come with built-in hard-disk utility software that scans your hard disk for errors and attempts to fix them.
1. Double-click on My Computer to open the My Computer window.
2. Select the disk that you want to diagnose and repair.
3. Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
4. Choose the Tools tab.
5. Click the Check Now button under Error Checking Status.
6. Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
7. Click on Start.
Aug 17, 2011 | Computers & Internet
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
Computer shuts down
Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
Thanks And sorry for the inconvenience.
Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    Dell b130 internal system restoration failed
    Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
    Aug 07, 2009 | Dell Computers & Internet
    IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
    check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
    Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
    Trubleshoot Motherboard
    More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
    System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
    Defective power cable. Visual inspection, try another cable. Replace cable.
    Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
    Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
    System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
    Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
    Defective floppy disk drive or tape drive. Turn system off.
    Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
    Defective expansion card. Turn computer off.
    Remove an expansion card. Make sure expansion card is secure in expansion socket.
    System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
    Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
    Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
    System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
    Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
    Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
    A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
    Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
    The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
    After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
    No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
    Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
    Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
    Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
    No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
    Monitor not connected to computer. See instructions above.
    Network card I/O address conflict. See instructions above.
    Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
    Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
    Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
    Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Screen saver is enabled. Disable screen saver.
    Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
    No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
    CMOS incorrectly set up. Call technical support.
    Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
    Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
    Bad floppy disk. Try new floppy disk.
    Floppy disk not formatted Format floppy disk(type ENTER)
    C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
    SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
    Hard Drive cable not connected properly. Check Hard drive cable.
    Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
    Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
    Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
    CMOS setup has been changed. Run setup and select correct drive type.
    Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Keys jammed or defective. Replace keyboard.
    Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
    Keyboard is locked. Unlock keyboard
    If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
    Oct 19, 2008 | Computers & Internet
    Laptop won't startup HELLP!!!!!!!
    what is the configuration of your laptop - i can't tell you the solution without knowing that
    Jan 07, 2008 | Microsoft Windows 98 for PC
    HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
