Question about Kenmore HE2 Plus Front Load Washer
There is power to the washer and all the buttons work, but when I press the start button it holds for one second, beeps and turns off. What is wrong?
  • sipplem Jan 02, 2011
    The error code comes up as F-01 saying the CCU needs to be replaced. Should I replace it or do you think it may be something else?
  • sipplem Jan 03, 2011
    Thanks for the speedy response.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
On something like this I recommend putting the control into a test mode so we can see what the last stored error code is. Once we know the error code we will have a direction to head into. Please see the images below that explain how to enter the test mode & the list of error codes.
Posted on Dec 31, 2010
  • Richard Roth
    Richard Roth Jan 02, 2011
    You need to replace the CCU on the machine.
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
When I turn on my PS3 will not load the basic applications, neither the games. When I press the PsS button on the cotroller to turn it off I will get the option but it will not tunr off and i will get a...
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button AGAIN, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
*****CHOOSE RESTORE FILE SYSTEM WHICH IS OPTION 3****
and DONE!!
www.1RepairStop.com
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 won't get to the main menu when I turn it on
    Ok, follow these steps to fix your PS3, unfortunately you will lose your save game data!!
    Step 1. Turn your PS3 off into standby (red light on)
    Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn off. Release the power button.
    Step 3. Press and hold the power button. It will beep when you first press it, beep 5 seconds later and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
    Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go onto the next step.
    Step 5. A menu will load. Select option 5 "Restore PS3 system". The console will ask you if you are sure, just accept and then the PS3 will restart. All the original software will be loaded and you will need to enter the date and time and other details.
    When you have done all this your PS3 should be fully working again.
    Hope this helps and thank you for using FixYa
    Aug 27, 2010 | Sony Playstation 3 (PS3) Console
    CANNOT START THE CORRECT HARD DISK WAS NOT FOUND
    To solve this problem follow these steps :
    Step 1. Turn your PS3 off into standby mode (red light on)
    Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then beep once more and turn off into standby again. Release the power button.
    Step 3. Press and hold the power button again. It will beep when you first press it, then 5 seconds later beep again and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
    Step 4. The PS3 will start up asking you to connect your controller via USB and press the PS button. Do this and then continue to the next step.
    Step 5. The recovery menu will load. Select 3 "Restore File System". This will rewrite the hard drive system and hopefully get your PS3 working again. You shouldn't lose any save game data but that is not guaranteed. Ignore any messages about the hard drive being corrupt.
    If the above method does not work try steps 1-4 again but select option 4 from the recovery menu. If that doesn't work as a last resort select option 5. Selecting this option WILL erase your data!
    I hope this helps and thank you for using FixYa
    Aug 20, 2010 | Sony Playstation 3 (PS3) Console
    Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
    try video reset
    when ps3 is in standby mode(red light)
    press and hold the power button till you hear a second beep.
    standby mode press hold power........"beep"......"beep"..release power button
    then try rebuilding the database and the file system in recovery consol
    to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
    like on my 80g system it goes like this
    ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
    Oct 20, 2009 | Sony Playstation 3 (PS3) Console
    No picture for ps3,i went to service menunand did something wrong
    You probaly turned hdmi on or off i dont know what your settings is,
    you can turn your system settings back to factory default using the Safe Mode.
    Step 2:
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
      safemode2.jpg //
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Playstation 3 (PS3) Console
    Ld code appears intermittantly
    ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
    Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Smart Drive 601 does not drain
    with the machine plugged in and turned on but not powered up this is what to do
    press and hold down the start button, then press and hold down the power button (hold down for 5 seconds) the washer may beep up to 3 times during this process
    next remove fingers from buttons, then turn off machine with the power button, then turn on again and only press the start button this will now reprogram the computer
    let it run untill end of cycle and this should fix prob
    Jun 11, 2009 | Washing Machines
    Kenmore HE2 Plus Front Load Washer Logo
    154 people viewed this question
    fordexpert
    Mike Squire
    Robert Rankin
