Question about General Electric DHDSR46EGWW Dryer
My dryer won't start when I push the start button. When I hold the start button down, it sounds like the timer is clicking. Any suggestions?
  • General Elec... Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
215 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
