Question about Toshiba Satellite Pro M10 Notebook
I have forget my bios password please help me toshiba satelite pro M10
  • Toshiba Master
  • 27,725 Answers
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Posted on Dec 31, 2010
Hi, I got a Toshiba Satellite Pro M10, Is there a way to remove Password?, i can not access to the O.S. (not even to the bios). Thanks
Yeah - if it's a BIOS password, but if it's a HDD password then you're screwed and there's nothing to do but replace the HDD.
For a BIOS password removal, either buy a parallel port password removal key, or make your own. Schematics can be found here: http://www.cgsecurity.org/wiki/CmosPwd.
Aug 05, 2011 | Toshiba Satellite Pro M10-S405 Notebook
Toshiba satellite Pro m10 power on password
If you power it on and get a "password=_" prompt, then it has a CMOS password set. The only known way around it is to buy or make your own parallel port key (aka parallel port password removal key - schematics are available free on the Internet) - which will clear the CMOS and set it back to its default state with no passwords.
Mar 30, 2011 | Toshiba Satellite Pro M10 Notebook
Toshiba Satelite Pro M10 doesnt boot
dvd drive you can remove from the backsdie opening the cover but display problem is becoause of faulty ram and the battery .remove the battery and try to on and clean the ram and fix it.
Jan 20, 2010 | Toshiba Satellite Pro M10 Notebook
What is the compatible ram for my toshiba satelite pro m10?
go to tigerdirect.com...find 1-800 number call them they will know what u r looking for
Jul 18, 2009 | Toshiba Satellite Pro M10 Notebook
What function keys to adjust my LCD monitor?
Use the fn key along with the f keys. There should be a picture either on or above each f key
Jul 02, 2009 | Toshiba Satellite Pro M10 Notebook
Bios password reset for toshiba lap top
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Mar 08, 2009 | Toshiba Satellite Pro M10 Notebook
Unlock bios password
i have forget my bios password please help me on Hasee laptop
Nov 20, 2007 | Toshiba Satellite Pro M10 Notebook
Bios password
on a desktop you remove the battery from mother board leave it out for 1 hour it resets the board and removes the password it should do the same on a laptop
Aug 21, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro M10 Notebook Logo
182 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
