Question about Black & Decker MX300 PowerPro Hand/Stand Mixer
My BD 250w hand mixer wont turn on. I only used it once. recently purchased. The first time I used it was to mix gingerbread dough. I then tried to use it a few days later, turned on the switch and nothing. No sound nothing.
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
I cannot remove the flat mixing blade, after mixing cake. It has never happened before, just doesn't move up down or sideways! it seems completely locked.
The blade sounds like it's jammed somehow perhaps simply with some food matter.
Ensure the mixer is not plugged in then try removing the bowl, locking the mixer in the down position and pushing up hard on the blade to try and dislodge it. If it comes free and lifts up then try wiggling and rotating it normally off the mount.
Sometimes with use the attachments can become slightly warped requiring more force to lift them before rotating off the mount.
I once used my own Kitchen Aid mixer with the dough hook attachment to make a whole wheat bread dough. When I was done the hook was a bit bent from the hearty dough. There was also some flour in the mount causing it to jam. Removing the hook attachment proved difficult but not imposable.
Good luck.
Apr 18, 2011 | KitchenAid Food Mixers
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
We just purchased the custom kitchen aid stand mixer on a boxing day special. We used it tonight to make cookies and then could not remove the bowl from the base. We are going to try the icecubes. If this...
The bowl screws into the base and can get quite tight if the mixer has been turning thick dough or other mixes. We usually tap the handle on the bowl with the palm of our hand a few times and that generally frees it. The other posibility is that the bowl was put into the base slightly askew. This could be more of a problem as this can cause the base plate to get damaged. Usually though if this happens you would have noticed some bad noises almost instantly you turned the mixer on.
Dec 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Black & Decker MX300 PowerPro Hand/Stand Mixer Logo
62 people viewed this question
Top Black & Decker Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
