Question about Kenmore 80012 Microwave Oven
Microwave runs but does not heat food. - Kenmore 80012 Microwave Oven
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 31, 2010
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
Microwave run with a different noise and stopped heating up food
heatman101
fkj
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE IS NOT HEATING FOOD
I did more research along with the suggestion of an apprentice to have person to fix the microwave. I was unable to fix it myself. The microwave needs a magnetron .
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Regarding microwave
Sanjay
This is due to the magnatron failing (this is the part of oven that cooks the food!) This is the most likely cause of y isssour oven not heating the food!
Magnatron needs replaced for oven to work again!
Please rate this free soultion!
Jan 18, 2009 | Sharp R-308J Microwave Oven
Kenmore 80012 Microwave Oven Logo
177 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
