We have a Muratec mfx 2030 printer fax scan copier and are unable to set up the windows & PC to send scans to a shared folder. It scans fine to XP machines but not the Windows 7. I can brows the network from the printer and see the Windows 7 PC but when I select it a user name and password is requested when I put a valid user name and password on the Windows 7 PC it gives me an invalid entry message. Not sure why its not accepting the user name and password
  • 351 Answers
SOURCE: New printer installation.
Dear,
you can download the fresh driver for your Multifunctional, from this site:
http://list.driverguide.com/list/company1620/
Cheerup and be happy always
Posted on Apr 10, 2008
SOURCE: Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Posted on Sep 25, 2008
sagarjd
  • 95 Answers
SOURCE: HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Posted on Nov 21, 2008
HeLpINHaRrY
  • 210 Answers
SOURCE: Unable to connect to Linksys BEFW11S4 router from new Toshiba lap
this sounds like security problems , other people have experienced problems with vista but most have been able to resolve them.
whilst connected to your router using an ethernet cable open a browser windows and type in the rounter address these
are usually one of 2 most likely yours is
192.168.1.1
and typing password as "admin" and no user name. Use your password if you have changed it earlier 2
Go to wireless tab. 3. Go to wireless security sub-tab 4. If security mode is wpa or wpa2 note down passphrase/shared key, if security mode is WEP note down wep key number 1. This will be your network key
also check other.
On the Vista laptop with the connection
Start --> Network
Click on Network and Sharing Center
if It shows a red X between my network and the Internet.
click on the Customize link (below and right of the red X)
Under location type if it was set to Public. change it
to Private. Hit Next
At that point my whole network might go down,  and
reset the router. (turned off and turned on)
After that my red X under network and sharing center
was gone. And my internet connection problem was gone.
I forgot to mention that before you shoul have turned
off all software firewalls and virus scanners. prior.
if that does not work when you are logged into the router page 192.168.1.1 check to see if their is an option to update the router software/firmware ,if their is no option then you  may have to manually downlaod the firmware from linksys and update that way .
Hope this helps if not ask for clarification on anything your unsure of.
Posted on May 14, 2009
  • 597 Answers
SOURCE: getting a validating identity message that stays there for minutes then I get little or no connectivity. Using WPA-personal with a 12 character password
I think the problem is the little or no connectivity. If you're not getting a good signal the verification process with your WPA and password is timing out before you can get verified. You probably need to turn antenna or get less blockage between you and source before trying.
Posted on Jun 01, 2009
Since upgrading to windows 10 I am unable to scan. Message Is Unable to write the file to this folder. Please make sure you have correct permissions to write to this folder. (CC3-107-00431005)
That sub folder is in a windows protected folder. See if you can create a folder un your libraries subdirectory and name is scanned docs. Then tell the scanner to send it to that folder
Aug 12, 2015 | Brother MFC-7420 Laser Multifunction...
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
I cannot connect my MFX 1300 printer to my home network. I have it connected to my ethernet hub but do not have the network interface card. do I need that?
Yes...the MFX-1300 was only a copier/fax machine when originally sold, so there was no facility to connect to a P.C.
To connect to a PC there was an Optional Printer Control PCB available.
Oct 19, 2010 | Muratec - MFX-1300 Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
Scanning a photo
Most Muratecs now a days do scan in color. The 2850 is one such model. So to answer your question you are incorrect.
Jan 16, 2009 | Muratec MFX-2830 Black and White Copier
Jun 22, 2008 | Muratec MFX-1430 Copier
Dear,
Apr 10, 2008 | Muratec Copier
Help with scanning on mour Ricoh Aficia 2035.
Since this is a  network printer, you can scan to folder,FTP site or email. alot will depend on your network enviroment. SMB is the simplest. The folder you are scanning to need permission to write to the folder. If you have email you need to enter your smtp server IP address in the user tools and an senders email address. the manuals with the copier will help or download them.
Oct 12, 2007 | Office Equipment & Supplies
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
