Question about Garmin nuvi 260W GPS Receiver
I left my garmin nuvi 260w in the car over night and now it wont turn on even when plugged in. I think it just got to cold in the car but i am not sure.
  • 321 Answers
Before you can detect if there is a problem with your garmin nuvi, You need to carry out some tests. First you need to check your battery, then you check your charger, then you check the device itself to know where the problem is from and how to solve them.
First test is the battery, try out a friends well tested battery into the device and power it on, if it comes on, then it means the battery of your device is either weak or dead, try to charge it on another device then power it on to see if it will come on. If it comes on, then the battery is alright and if it does not come on, then it means the battery is bad and you need to replace it.
Next test is for you try out your charger on another device to see if it will charge the device, if it charges the device, then it means it is alright and if it does not charge the device, then it means the charger is bad and need to be replaced.
The last test is for you to connect your garmin nuvi to a computer and power it on to see if it will come on. If it does not come on, then it means there is a problem with the connection port or there is an internal problem or something.
After carrying out these tests, you will be able to tell where the problem is from and fix it at the same time.,
Hope this information was helpful to you.
Posted on Dec 31, 2010
My garmin nuvi 260w want hold a charge
bad battery or voltage not reaching from the charger--I would test for voltage first from charger or if using lighter adapter the fuse in it.
Nov 06, 2012 | GPS
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
http://www.gpscity.com/garmin-dezl-560lmt.html
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
How to unlock the garmin nuvi 260w
  • 1
    Turn on your Nuvi 260W.
  • 2
    Enter the four-digit PIN you chose when you locked the device. If you have forgotten the PIN, proceed to Step 3.
  • 3
    Drive to your security location. When you reach your security location the Nuvi 260W will unlock automatically. If you forgot your security location or cannot drive there, proceed to Step 4.
  • 4
    Call Garmin to unlock your device. You need your receipt to complete the process. Call 1-800-800-1020 in the U.S., 1-866-429-9296 in Canada. See Resources for the Garmin support webpage.
  • Mar 05, 2011 | Garmin nuvi 260W GPS Receiver
    Hi i left my garmin nuvi in my works van over night during the realy cold weather and when i went to use it again it wont work it just comes up garmin then says loading maps and brings up a load bar which...
    Did you let the unit warm to atleast room temperature before you tried to turn it on again? Often when a unit gets really cold the screen will have troubles refreshing. If the unit was at room temperature then it may have water damage, try keeping it in a vat of rice for 2-3 days and then try it again.
    Hope this helps!
    Feb 16, 2011 | Garmin nuvi 255W GPS Receiver
    Garmin nuvi 260w is not charging with car charger
    You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
    May 29, 2010 | Garmin nuvi 260W GPS Receiver
    Nuvi 260 won't turn on at all.
    Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
    Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
    Garmin Nuvi 260w not recognized by computer
    Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
    It worked for me and my Zumo550
    Goodluck
    Auke
    Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
    Proper charging advice for Nuvi 260w
    Turn it off and Always unplug it when you're done with it.
    That's assuming you have a live plug (stays on when car turned off)
    Mar 16, 2009 | Garmin nuvi 260W GPS Receiver
    Nuvi 260w no power.
    Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
    You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
    1. Unscrew and remove the silver or black, round end piece.
    1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
    2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
    Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
    Garmin wont read street names anymore
    To activate the voice prompts, go to 1. Tools, 2. Settings, 3. Language, 4. Voice Language Option, 5 Select a Voice Option that includes a persons Name, eg Jack or TTS, Select OK and that should resolve your problem.
    Dec 08, 2008 | Garmin nuvi 200W GPS Receiver
    Garmin nuvi 260W GPS Receiver Logo
    124 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
