Question about Kitchen Ranges
When I use the Bake feature, the Convection Bake, or Convection Grill features, I get this message in the display: Err It beeps and the oven does not come on. Model #GRCR3965ZSS-1
jessee007
  • 310 Answers
SOURCE: Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
Posted on Jan 01, 2008
SOURCE: "Err"or message with beeping
Same message here. Did anyone buy it a costco? I'm hoping they'll take it back. Andrew Victoria BC
Posted on Mar 01, 2008
  • 1073 Answers
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
SOURCE: My NEC Dterm Series E 16D-1 does not display the MUTE feature
I have a NEC DtermIPK IP phone at my desk and would like to cancel the feature of my voicemail forwarding to my cell phone.... Can you help?
Posted on Jun 20, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Does a mivrowave grill glow red when in use
    It might if it is a convection oven
    Aug 26, 2017 | Televison & Video
    The control panel of my sharp grill 2 convection microwave oven is very dim
    Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
    Regards,
    Dan
    Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
    Kitchenaid kera205pss convection oven feature not working
    Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
    Apr 20, 2014 | KitchenAid KERA205PSS Electric Kitchen...
    Feature not available
    I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
    Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
    Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
    there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
    Nov 29, 2010 | Thermador CM301U Electric Single Oven
    700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
    The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
    Oct 02, 2009 | Bosch HBL 455 Stainless Steel Electric...
    My upper oven/ convection function on my dacor ecs230b will not heat
    Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
    Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
    Samsung Bake & Toast Microwave MT1066SB starts heating but shows
    getting t-4 on clock display and random beeping<br /> cancelling and unplugging don't fix it<!-- from fixya rte -->
    Jan 15, 2009 | Samsung MT1066SS Convection/Microwave Oven
    Err on display when I try to set the bake temperature
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    or try doing this
    1. Turn the clock selector knob to OFF
    2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
    Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
    Oct 14, 2007 | Oster 6239 Toaster Oven with Convection...
    Kitchen Ranges Logo
    32 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
