Question about Samsung Televison & Video
I have a ghost of a black bar on the left side of my 61"dlp.
    Novelist:
    Champion:
  • 203 Answers
It sounds as though your light chamber is collapsing. This is caused by intense heat from the lamp inside the light engine causing the glue to melt that holds several tiny mirrors in a pyramid shape. This is a very intricate repair but can be performed relatively cheap compared to the replacement cost of entire light engine if you find the right service person. Look for an authorized service center or at least someone who knows what the expression light chamber collapse means. The small group of mirrors is located right behind the color wheel and requires the lamp, ballast, color wheel and housing to be removed in order to be replaced. Caution should be used when replacing this fragile compenent.
Posted on Jul 08, 2008
DLP chip replaced, now black screen and error code 61
Could be bad conections, I gues. I have downloaded the service manual of: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf In manual you can find more information about the problem. Luck! http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf b16238c1-e835-41b2-9320-a038bc07b019.png c23b3cd8-57ed-484d-b6b2-3c2c86547319.png
Jul 09, 2014 | Mitsubishi WD-73733 73" HDTV
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
My 61 inch sony DLP ,i think a '07 just black out
You check the power supply section and the horizontal section
May 04, 2012 | Sony Televison & Video
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
2-3 inch bar on the left side of my samsung dlp
Is it a wiggly image in the bar or is it completely black. Does it move with scaling the aspect of the image. (aspect button)
Jun 26, 2009 | Samsung HL-R6167W 61" HDTV
Samsung DLP HL-R6167W 61"
try removing the lamp again ,inspect it for hair and blow some air into the lamp housing,if this is new to you after replacing the lamp,its possible its been created .
Jun 14, 2008 | Samsung DLP HL-P5663W 56" TV
Large black bar to the left of screen
When replacing the light tunnel, the new one must be installed exactly as the old one came out. This can only be done by marking the screws and backing them our exactly 3 or 4 revolutions and then tightening the new one the exact same revolutions. When looking into the old tunnel you should have been able to see the mirror that came unglued to ensure that was the problem. The problem now can be corrected by loosening the screws on the dmd bd and manually adusting the dmd position in association of how it hits the dlp chip.
Feb 17, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Toshiba DLP TV
Light engine issue I would say, is it somewhat transparrent? if totally black might be something else but more than likely will be a light path issue inside the light engine.
Jul 17, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Open Questions:
Televison & Video Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
