Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Refrigirator Temp controller button making noise- I've a Samsung CoolTech Plus for 8 years. It's on good condition except the refrigirator temperature control button is emitting noise from time to time (at least 3 times a day). I notice usually at night. (The noise is the same one as emitted when the button is pushed to change the temperature). What does that mean? How can I fix the problem and what should I do to prevent it emitting noise?
  • Samsung Master
  • 8,220 Answers
Try raising the legs up on the front just a hair. This will shift the weight of the ice box to the rear and force the doors to close tighter. Then the beeping may go away.
Posted on Jan 03, 2011
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
What is the ideal temp setting in GE side by side refrigirator. I have Freezer (0-9) Refrigirator (0-9) There was ice on the Freezer wall and the service guy replaced the defrost thermostat recently
If replacing the defrost thermostat fixed the icing problem that doesn't indicate your settings are wrong. But the desired temp in the freezer is from 0 to 10 degrees and in the fridge around 35 degrees.The actual number on your dial depends on the personal use. Use a thermometer to check it and allow 24 hours after changing it to check it.
May 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
LG 252
Loan it to a friend to use in their home or garage, it will be in good shape when you get back and it will be a blessing to them and you.
Sep 13, 2017 | LG LRTBC1825T Top Freezer Refrigerator
Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Apr 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
I have a side-by-side Samsung refrigirator RS24FAMS. There is bad smell coming from the back of it. I took off the panel at the lower back but found nothing suspicious. The smell is not from inside the...
there is a drain pan over there next to the compressor ...the old water get there and dry out ...see with flash light all over you might need to clean it (turn unit off) and do it gently ...good luck use some cleaning spray...
Jan 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need help
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
May 27, 2008 | Maytag MSD2756G Side by Side Refrigerator
Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
