Question about Frigidaire Dishwashers
I have a frigidaire Dishwasher FDB750RCC1, My timer has gone bad. I've got the panel disconnected from the unit, but can't figure out how to remove the timer from the panel. I don't see any screws and don't want to pry and break something.
4 Suggested Answers
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
SOURCE: Frigidaire FDB750RCC1 Dishwasher
I have the same problem (I think). Did you ever find a solution?
Posted on Feb 21, 2011
Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher is not spraying any water inside
Hello & Welcome to FixYa
When the water comes however, won't go inside the unit then it indicates that the problem is either with a clogged/blocked inlet valve or the water inlet valve itself has gone bad and needs replacement. You can also test two terminals of the water inlet valve before replacing it.
If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Frigidaire FDB1502RGC Built-in Dishwasher
The buttons on my Whirlpool dishwasher have gone haywire and have a mind of their own. I can't push a button to start the dishwasher
Hi!!
Try disconnecting the power cord for 5 min. to see if the unit will reset itself. If that does not work, disconnect the power cord and remove the inside panel behind the control board to check the circuit board for burnt marks or smell. If found defective, click on the following link to ID and order the correct part. http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-GU3600XTS-%3d%3dec13
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 02, 2010 | Whirlpool GU3600XTS Dishwasher
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
Good luck hope this helped you some
Dave
Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
Hello, I have a Frigidaire Dishwasher, model FDB750RCC1. It will not fully drain. There is water in the bottom of the unit after the cycle is complete. As it is not full of water or leaking out of the...
On the drain hose at the connection to the dishwasher there is a one way check valve. If debris has gotten trapped water will drain back into the dishwasher at the end of cycle
Hope this helps.
Remove the connection and clear.
Jul 01, 2017 | Frigidaire 24 in. FDB750RCC Stainless...
My dishwasher ran for 4 hours last night. When we realized that, we opened it and it was still soapy. Is it likely that I need to replace the timer?
If the unit is not heating, it will run waiting for temp to be achieved. Check that there is a cut out stat on the heater. Reset this by pressing it. If not, check that the thermostats and or heater are okay.
Dec 11, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Gallery dishwasher smoke coming out of door. smells like wires burning.
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
Nov 12, 2009 | Frigidaire 24 in. FDB636GF Built-in...
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Frigidaire dishwasher ultaquiet , model=FDB750RCC1
Jan 17, 2008 | Dishwashers
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
