Question about Samsung WF337AA Front Load Washer
Water is coming out from the bottom of the door, there is a little warp to the door gasket right at 6 o'clock. Does the door gasket need to be replaced or is there a remedy to fix the seal. Thanks
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
without being able to inspect the warp, I will have to say no. if it was cracked or torn, you could make a temp repair. but in the long run. the gasket has to be replaced, and it not a easy task.
You really should have a experienced service person, look at the warp to figure out why it happened.
The door gasket is not cheap. and you may another issue, for why it was warped.
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Thank you"
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
LG Dishwasher leaks!! New E1 Code just fixed an HE Code, gasket not broke, one of the electrical connections underneath had come loose so I just clipped it back on. I have not hooked everything up again...
http://lgdishwasher.yolasite.com/ MINE JUST STARTED AGAIN TODAY. SWOLLEN BOTTOM DOOR GASKET LOOKS LIKE HILLS UP AND DOWN. ALLOWING WATER TO OVER FLOW DOOR BOTTOM. GETS TRAPPED BEHIND GASKET. PAN HAS LITTLE WATER WHEN YOU OPEN DOOR. BUT CAN SEE RUN OUT OVER EDGE WHEN RUNNING WITHOUT OUTER DOOR SKIN, ALSO LEAKS AT TOP CORNERS DUE TO DEFORMED CORNER GASKET. THEY SHOULD HAVE MADE THE GASKET ROUND IN CORNERS TO KEEP IT SEALING, HAD TO MAKE C METAL CLIPS 4 INCHES LONG TO HOLD BOTTOM GASKET TIGHT TO BOTTOM PAN, USED 4 CLIPS AND TWO SMALLER AT ENDS
Oct 18, 2013 | LG LDF6810ST Stainless Steel Built-in...
Need new gasket
http://diygaskets.com/search.asp
If you model number is correct these guys will have it.
Aug 25, 2012 | Freezers
How do I install gasket on doors - top and bottom on Amana Model DRT1802B
Buy a gasket that fits your door exactly.
Step 2
Soak the new gasket in hot water in the sink to make it pliable.
Step 3
Make sure the refrigerator is level.
Step 4
Find a nut driver that will fit the screws holding the old gasket in place and lay out your tools where you'll be able to reach them.
Step 5
Start at the top outside corner of the door and fold the old gasket back as you partly loosen the screws along half of the top and side. Don't loosen them all the way.
Step 6
Pull the old gasket out.
Step 7
Attach the new gasket by pushing it beneath the metal retainer and tightening the screws as you go.
Step 8
Replace each section the same way.
Step 9
Shut the door and check for gaps. The seal should lie straight and smooth all the way around the door.
Step 10
Notice if there are gaps between the gasket and the frame - this may indicate that the door has warped. (Fix it by loosening the screws and twisting the door a little. You may have to do this a few times before you get the door straight.)
Step 11
Put a flashlight in the freezer pointed toward the opening and shut the door. Turn off the lights. You shouldn't see any light leaking through.
Good luck and hope this helps............
Jul 29, 2010 | Amana Refrigerators
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Door on right opens as if the magnet is not strong enough.
clean the area where the magnetic door gasket contacts If the gasket appears warped
use your hairdryer on medium to gently heat the magnetic gasket pulling it out toward the door opening to restretch it
May 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
How do i adjust doors so that they close on their own?????????????
Below is instructions on how to make sure doors open and close properly. Ignore the popping open part if this is not happening for you.
Mar 20, 2009 | GE Refrigerators
Kenmore Frig-bottom freezer/freezer door pops open
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag front loading washer
first check that gasket around door for rips tears and warpped condiction..if that not the case this will help...easy now go slow than check unit,,grasp the door and bend SLOWLY..from bottom of door and hinge,,because sometimes we hang wet clothes over the door ,and bend the hinge..the last but neat trick is to put 2 washers behind the door latch lock..between the door latchlock,,and the inner panel..that will push the latch back and make the door itself get tighter against the gasket..dont worry about the extra water that is just a flush down,,,keep me posted onthejob
Jan 10, 2009 | Maytag Washing Machines
Samsung WF337AA Front Load Washer Logo
407 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
