Breckwell big e keeps blowing fuse on the control board
3 Suggested Answers
david04928
  • 102 Answers
SOURCE: Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Posted on Mar 11, 2009
  • 51 Answers
SOURCE: the fuse on the control board keeps blowing and
CHECK FOR A SHORT SUCH AS A WIRE TOUCHING ANOTHER WIRE OR THE BOARD TOUCHING METAL. MAKE SURE FUSE IS CORRECT AMP. ALSO TURN POWER OFF AT THE OUTDOOR UNIT AND CHECK TO MAKE SURE THERMOSTAT WIRES ARE NOT TOUCHING. IF NONE OF THESE SUGGESTIONS WORK THEN CHANGE YOUR THERMOSTAT. THIS SHOULD SOLVE YOUR PROBLEM.
Posted on Apr 13, 2010
Carver r2000 keeps blowing fuse
Fuses blow when there's an overload. The most likely cause being a short-circuited semiconductor(s) located on the big heatsink. Other causes are a shorted device in the power supply section. Such as a rectifier or voltage control device.
Transistors tested with an ohm meter will show up as if you have touched the leads together when connecting across the terminals.
Oct 12, 2014 | Carver Audio Players & Recorders
1993 Goodman gas furnace keeps blowing fuse when first turned on
You can take each thermostat wire off the control board and use a ohm meter and test to ground, should not have any resistance. Another way is turn off power take each wire off the board, then place one wire at back on the control board terminals ome at a time, untill the one you get to the one that blows the fuse. If the wires check out good sometimes the thermostat itself can have a internal short and cause the fuse to blow.
Nov 27, 2012 | Heating & Cooling
Audio video control center fuse keeps blowing
check all ur grounds
. see if theres 1 from board to cabinit.
May 08, 2012 | Audio Players & Recorders
When turn on it blows the fuse
There must be a diode that is faulty in the power supply section mainly on of the rectifying diodes.
If you look closely at your board you will see four diodes that just after the fuse and befroe the Big capaictor(filter cap.) One of these four diodes must be faulty as the fuse keeps blowing. the diodes are responsible of current limitation drawback. So there must be current flowing back to the fuse that makes it keep blowing.
Check and replace. Good luck
Thanks for using Fixya.
G.
Jun 27, 2011 | Pioneer SX-205 Receiver
Does thermal fuse burn out only because of temp.?
Possibly or the thermo fuse just went bad normally if the thermo-fuse blows its a venting problem warm moist air back builds into the dryer which in turn blows the thermo-fuse to save the dryer from further damage and also keeps from starting a fire in your home a big saftey feature that has saved many homes.
Jan 04, 2011 | Maytag HYE3657A Electric Dryer
# 15 fuse keeps blowing, no windows, no wipers, shift locked...What could be the proplem...noticed that cruise control went out a few months back
possibly the cruise cancel switch on the brake master cylinder is shorted, disconnect the switch and replace the fuse and see if everything comes back to life. the switch may be on the end of the master cylinder, Ford has had BIG problems and RECALLS for this switch going bad.
Sep 23, 2009 | 2001 Ford F150 Styleside SuperCrew
The big 40A fuse under the hood keeps blowing when
youll have to probe that elec.circuit to find what is causing your short
Feb 25, 2009 | 1998 Chevrolet Blazer
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Dishwasher
There is a short there, in control panel circuit board,that's why your fuse is keeps blowing.Trace the electrical connection from down to up to control panel board. Check for short capacitor and diode..Feel free to ask whatever the result..
Hope this may help you;
DON'T FORGET TO RATE;
Sep 03, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Open Questions:
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
