Question about Garmin Nuvi 770 Car GPS Receiver
Just got new battery put in because of recall only used one time. Turned on garmin and garmin screen came on and is stuck on this screen. Does not turn off or on What's up?
  • 321 Answers
Your device freezed that is why it is stuck on the garmin screen. You need to first reset your garmin by holding the power on/off button for about 15 seconds, that way it will restart.
About the battery, when you get a new battery for your device, you need to charge it for about 3 hours before powering on, once you power on without charging it first, then it might kill the cells of the battery as they are lithium ion battery. What you have to do is to remove the battery, insert it back, then you plug it to a power source for about 3 hours, be sure that the battery is charging as the green light comes on as you plug it. If the green light does not come on, then you need to connect it to a computer using your USB cable, that way it will charge. Once it is charged for about 3hours, then you will be able to turn on your device. First reset, then charge battery. That should do the job for you.
Hope this information was helpful.
Posted on Dec 31, 2010
Snopes truth fiction
As mythbusters would say : Plausible.
Garmin's use Lithium Ion battery technology which can explode and catch fire. Garmin issued an older series of devices a Battery Recall because of some reported instances call their support number and they can tell you if your Garmin serial number has been recalled. Understand though that it is a battery issue and many companies have dealt with exploding batteries. Try reading this for more info.
Why lithium batteries keep catching fire
Jul 19, 2014 | Garmin GPS
Garmin Nuvi 755t Stuck in power up cycle
You can do two things.
First, plug the GPS in overnight in a regular USB charger. If the battery charges up, then the problem is with your Garmin vehicle cable.
If it does not charge up, you can buy a battery replacement kit for it: https://www.amazon.com/Garmin-Nuvi-755-Replacement-Installation/dp/B003VFSR4M
Mar 05, 2017 | Garmin nuvi 755T Car GPS Receiver
I have had my Garmin for four years. Recently it has started shutting off when I'm driving with the set plugged into the adapter outlet. If I press the power switch, it will reboot, but then after a...
Garmin is voluntarily recalling certain nuvi devices that contain a specific battery that was manufactured by a third-party supplier within a limited date code range.
Garmin has identified potential overheating issues with the use of these batteries in certain nuvi devices with a specific printed circuit board (PCB) design. Additional information about the nuvi battery PCB recall can be found in Service Alert Number: 1035.
The models that may be impacted by the nuvi battery PCB recall are the 200W, 250W, 260W, 7xx and 7xxT (where xx is a two-digit number). To determine if your unit is affected, please visit www.garmin.com/nuvibatterypcbrecall and enter your nuvi's serial number. If your unit has the specific PCB design and contains a battery from the specific date range, you will be given instructions on how to return your nuvi for a battery replacement at no charge.
You should not attempt to remove or service the battery on your own; all battery replacements must be serviced through Garmin's authorized service provider.
If you do not have web access, you may contact Garmin through one of the phone numbers below:
  • In the United States and Canada, call (866) 957-1981
  • In North America and South America outside the U.S. or Canada call (913) 397-8200
  • In Europe, Middle East, and Africa, call +44 870 850 1242 or 0808 238 0000
  • In Asia, call 886/2.2642.9199
  • In Australia, call 1800 113 738; and in New Zealand call 0800 427 652
Repair time will vary based upon location. U.S. customers, please allow 10-16 business days to receive your repaired or replacement device. Canadian customers, due to increased shipping and customs clearance times, please allow 20-30 business days to receive your repaired or replacement device.
Garmin sincerely regrets the inconvenience that this recall has caused and is making every effort to cooperate with customers, dealers, and regulatory agencies worldwide to ensure all parties are assisted according to national regulatory standards
May 24, 2011 | Garmin Nuvi 660 GPS Receiver
I just received my neww 1450LM Garmin Nuvi GPS today and it push the on/off power switch and it does not come on. so, I started my car and plugged it in and it still does not come on. Please tell me why it...
May 24, 2011 | Garmin Nuvi 1450LMT
After charging my nuvi 1450LMT for four hours, I disconnected it from the power cord and left it overnight. When I turned it on the next morning, I got the Garmin logo, then a white screen flashed on...
How did you charge it? If you did not use a high power USB charger, try that overnight. A USB charger provides a lot more powr than your PC. Leave it plugged in and off overnight.
If that does not work, Amazon sells battery replacement kits.
Apr 09, 2017 | Garmin Nuvi 1450LMT
Is my Garmin nuvi 260 in the battery recall?
Yes. There is a battery recall for this model.You could check the below link :-
https://my.garmin.com/rma/recallLanding.faces
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin nuvi 260W GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
Garmin nuvi
Hi Matt,
That function normally comes up when you put your finger on the upper right corner of the screen and hold it there while you turn it on.
Have you tried pressing the reset button under the antenna?
- Jim
Sep 17, 2008 | Garmin nuvi 350 GPS Receiver
Garmin ique 3600 won't turn on after battery goes dead
I had the identical problem; I called Garmin and a new battery = $50, installed only @ the factory. I tried buying one off eBay, but those batteries spec out ok but don't have the pigtail leads required for my M3 (probably would work just fine for M5). I soldered on the pigtail from the old battery from my M3, then put it all back together. Works! However, the new battery ultimately drains down over several hours so when I'm not using it I have to trickle-charge the thing constantly. Bottom line: I suggest sending your M3 back to the factory for a new battery rather than trying to replace it on your own.
Jan 25, 2008 | Garmin iQue M3 Pocket PC GPS Receiver
Screen Blanks
SailorMan,
Contacted Garmin Tech Support and they verified the problem with the WAAS. They said the engineers were looking at the problem. Estimated the fix would be ready in 2 to 3 months. I turned the unit on inside where the unit could not receive any satellites then disabled the WAAS and the unit works without problems. It is just not as accurate.
Oct 19, 2007 | Garmin GPS 72 GPS Receiver
Garmin Nuvi 770 Car GPS Receiver Logo
214 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
