Question about Garden
How to remove bent augers from craftsman 27 inch snow thrower. model #944.528393
    Novelist:
  • 171 Answers
There is no repair manual for Craftsman snowthrowers including the Husqvarna built ones like yours. Sears trains their techs to repair these, but not the general public.
Here is the operators manual. It includes detail parts listings so you should be able to go off them to tear the unit apart.
http://www.managemylife.com/mmh/owner_manuals/25209/CRAFTSMAN-Snowthrower-Gas-L0909438?brand_name_search=craftsman+52839
I suggest you split the snowthrower from the power unit and put it on a workbench at a convieninet height for you to work from.
On page 22 of the manual is a parts breakdown of the impeller/blower area. Use this to tear your unit apart.
Feel free to ask anymore questions.
Posted on Jan 11, 2011
Service manual for craftsman 24" snow thrower
the only thing holding in the auger is the block bearings on each side (three bolts in each side) the center drive is hex splined and should come right out ,unless its bent as well.
if you call 1800sears parts with model and serial number they can get you a new auger assmebly mailed right to your door
Feb 24, 2015 | Garden
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Craftsman 27 inch snowblower manual
Howdie Does it Move manually or is ther crank to turn it ?
Feb 13, 2014 | Craftsman Garden
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
My auger stops rotating with heavy snow loads. It sounds as tho a clutch is slipping. I tried to tighten up on the spring in the control cable, but that did not help.What do I adjust next?
The most common cause of this is the drive belt is worn. If you remove the cover in the middle of the snow thrower and look at the belt farthest from the motor. This is the auger/blower drive belt.
With the engine not running, have someone depress the auger lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
I didn't see what make and model this blower was but:
If this is a craftsman you can get parts through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Jan 01, 2011 | Garden
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
