Question about Video Game Consoles & Games
Can't find right channel for xbox 360 - Video Game Consoles & Games
  • Matt912 Apr 14, 2009
    My xbox recently had the rrod but i cured this by using the towel method. Ever since, I have not been able to locate a channel for the xbox 360 to be played on? Someone help me!?
    Problem Solver:
  • 6 Answers
On your television?
xbox360 comes standard with a scart cable so its not on a channel as such, try changing the source using the remote control for the television, it should come up with an AV or EXT channel. if still no luck ensure that the scart is correctly inserted into the slot (it sounds stupid but they fall out very easily and can cause loos of picture or sound or both)
Posted on Jul 08, 2008
No signal when xbox 360 is on
Have you got it on the right av or whatever you have put it on check every channel like av
Mar 27, 2010 | Microsoft Xbox 360 Console
Tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
File Extensions: .avi, .divx
Containers: AVI
Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps.
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
Audio Max Bitrate: No restrictions.
2. H.264:
File Extensions: .mp4, .m4v, mp4v, .mov
Containers: MPEG-4, QuickTime
Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
File Extensions: .mp4, .m4v, .mp4v, .mov
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
File Extensions: .wmv
Container: asf
Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps.
Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
on Apr 06, 2010 | Audio Players & Recorders
Need help with xbox 360
There might be more then 1 AV cable sockets to plug into. Or your simply on the wrong AV channel. Try searching around!
Feb 18, 2010 | Microsoft Xbox 360 Console
Hello My xbox 360 sound is not working any more. can this be repaired easily
I doubt this is a console problem, if you go to your my xbox page, scroll over to the right to the system settings page, click console settings, click audio, here you can alter the settings for your audio.
It could also be a problem with your tv channel, could you try a different channel for your games.
Remember thumbs up if this works.
Feb 05, 2010 | Microsoft Xbox 360 Console
My xbox 360 is not showing a picture all i get is the audio function
is it on the right channel is it got the right lead on it is it plugged in properly?
Jan 30, 2010 | Microsoft Xbox 360 Console
Why does the xbox 360 not show anything on the tv but i can hear things
sounds like a short in the video cable or the tv is not on the right channel
Dec 23, 2009 | Microsoft Xbox 360 Console
Logitech harmony xbox 360 remote not communicating with 360.
There is a setting that may need to be changed within the Xbox 360, to allow it to be controlled by a Harmony Advanced Universal Remote.
To configure your Xbox 360 to respond to a Harmony Remote
  1. Using your original Xbox 360 controller, go into the Xbox Dashboard on the Xbox menu
  2. Select "Console Settings"
  3. Select "Remote Control"
  4. If "All channels" is selected, select "Xbox 360 Media Remote”. If "Xbox 360 Media Remote" is selected, then select "All channels"
Your Harmony remote should now control your Xbox 360
Oct 20, 2009 | Logitech Harmony 360 LCD Remote Control
Why does my xbox 360 make a loud noise when turned
try putting it into your TV if you have inputs and if you dont have any on your TV try a VHS player and put them in and scroll down to the channel L2 it will say that on the top right corner of the screen
Jul 29, 2009 | Microsoft Xbox 360 Console
Not Support
HD TV?
Do you have more than 1 channel for gaming?
I have 7 HDMI/Something 1/2/3 and Something 2 1/2/3/
Said something because cant think of it right away..
But yeah make sure the video plugs are plugged in/ and to the right spots.
Nov 26, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
44 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
