Question about Toshiba Office Equipment & Supplies
Code "CE20" red wrench appears
  • scallydu7 Dec 31, 2010
    Nina. thank you for that, but no one is available for tech support today and we have a rush order. I was hoping there was a quick solution to problem. We cleaned sensor, because they said that was the problem and simply use air to clean. Worked one or two times, turned on and off machine. Help
    short term solution. What do you think? Help! Thanks
    President:
  • 3,278 Answers
Hello.
This may not be the answer you want, but if you called for service and the tech did not fix the problem, the tech should return without a charge (if there was a fee).
For any service, for a computer, copier, auto or anything, if a service tech does not do his or her job and fix the problem. they need to return to complete the job.
Hope this helps.
Posted on Dec 31, 2010
  • NinaE Dec 31, 2010
    From your description, my guess is that it could be a faulty sensor. Is it possible to use your very short-term solution to step-by-step get through this project until the copier gets fixed ??
    I was referring to cleaning the sensor each time and slowly completing the job.
A RED WRENCH HAS APPEARED
There are hundreds of error codes that will display call for service with a wrench. What is the error code on the screen?
Jun 22, 2014 | Toshiba E-Studio 456 Multifunction Copier
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
Yellow wrench in mercury mariner hybrid
The Yellow Wrench is what ford calls a MIL Lamp
That technology shouldn't be new to you or what you
do next
OBD2 Systems have been on all vehicles since 1996
All veh are the same
Any dash light you check for codes with a day or so,if
you want to know what the issues might be, then google the codes
I would just go to a repair shop immediately at any check light
being on.
You shurely know that a dealer is Never needed to work on any
vehcile & you also should know they charge more,a good reason
not to be there even with a new a car unless you there for free
warranttee work only
Yes you will pay $100 every time the dash light comes on
These shop have big investment in test equip
Finding the issuse if sometimes the entire job,the fix is not
always a big deal
Very bad advice for a dealer to tell you to continue to drive
a vehicle when they have no idea what is wrong.
You need those codes day one to determine if you should use it
Buy yourself a $60 code reader & google the codes on any
& all your vehicles so you can decide if you should be using it
at all.
Jan 21, 2013 | 2006 Mercury Mariner
Red light
Hi, Anonymous here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
For more information about your issue, please visit the websites below. Good luck and have a nice day
DOWNLOAD 2006 Aprilia Rs 125
Jun 17, 2012 | 2006 Aprilia RS 125
I have the wrench on in the color red and an error code of SC541. Copier does not allow copying in this mode. I tried "Clearmode" button, then numbers 1,0,7. Then I held down the...
Yes, this is a fuser error code. You're doing all right .
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And that´s it...
It is true that this code can appear more on cold days but it is already the second time it appears. You must have thermistors making bad reading. This may be caused by crusted toner or tired. You can also have the roller fusion whith toner crust. In any case I advise you to call technical intervention.
Do the procedure that i told you to be able to work with the machine.
Jan 22, 2011 | Ricoh Aficio 450 Copier
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Minolta EP5420 Malfunction Code CE20
Hello sir; The particular code you post for minolta EP5420 means blanking lamp problem.try to reset;
There have a service switch under the panel and behind the toner bottle. you will find a small access hole. you may use paper clip stick into the hole to reset, otherwise you have to replace the lamp.
Jan 03, 2009 | Office Equipment & Supplies
222 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
