No water is coming through when HOT water temp is selected. only on COLD. and COLD comes through when WARM is selected.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
sounds like your temp selector control is defective..
try this
on warm or hot, turn off the cold water valve at the wall.. you should get hot water, if you dont..you may have a defective hot-water inlet valve
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Thanks for the quick response!"
No cold water coming into machine
Follow the cold water line inside the washer where it connects to a 'Fill Valve' which is a valve/solenoid. Using an electrical test meter check the two wires at the solenoid for 110 volts when the machine is calling for cold water. If there is voltage but no cold water the valve is most likely bad. You may also want to pull the hose to make sure you have water running through the hose from the spigot. With the hose off at the valve look to see if there is a screen at the valve that might be clogged.
Dec 04, 2013 | Roper Washing Machines
Why does cold water mix with the hot when the switch is set on hot
Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again. Hope this helps
Sep 06, 2012 | Admiral AW22 Top Load Washer
I am getting warm water when we have selected colc/cold. I have checked the cold water intake and it works. In fact, if I shut the hot water intake, I only get cold water for the wash. What is causing...
If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
Feb 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WPXH214A Water Temp: Any selection that has Warm
The cold side of the water valve is either clogged or not opening. Take the cold water hose off of the machine and see if the screen is clogged. If clean you may need to replace the water valve.
Feb 25, 2010 | GE WPXH214A Front Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
HOT WATER NOT COMING INTO MACHINE
lets see hear.what the water fill hoses are connected to is call the water fill valve.when you select a water temp.,electricty will then go to ither water valve coil or both for warm.so if your not getting hot it could be first that the fill screens at the hose at the water valve is blocked .but most of the time thats not true of hot because minerals drop out in the water heater before getting to the water valve,unlike the cold water.so if screen is clean,next would be voltage to the water valve.if its getting voltage but not working then its the water valve.if its not getting voltage then use the wiring diagram to see what componet is before the water valve.may be water selector switch or timer
Jan 03, 2009 | Maytag HAV3460AWW Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Our GE washer WASE5210B3WW will only go in the rinse and final spin cycle when turned on.
HI THANKS FOR YOUR QUESTION ,wHEN YOU SELECT nORMAL WASH dOESWATER COME IN. IF NO LOOK AT THE WAETER TEM SETTINGS YOU HAVE SELECTED iF THE WATER TEMP SELECTOR IS SET FOR HOT AND NO WATER CHANGE THE WATER TEMP TO WARM IF COLD ONLY COMES IN YOU NEED A WATER VALVE .tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Sep 12, 2008 | Washing Machines
My Atlantis Oversize Capacity Washer is the problem.When I select a Warm/Cold wash the water starts out warm, then kicks into hot water. So then I have to hit the Warm/Cold button over and over as it fill...
The temp is controlled by a thermistor to make sure the warm water is warm. If the incoming cold is too cold, or the incoming hot is not hot enough, it will compensate by turning off the cold until the temp comes up, then it should turn the cold back on. Make sure the hot supply is to the hot water valve. If the hoses are backwards it won't work right either. Or you may have a bad solenoid in the water valve. It's possible for a water valve to work when it's cold, but as electricity runs through it, the solenoid heats up and causes it to open electrically which will close it mechanically and turn the water off. Usually if this is the case it won't open again for at least 10 minutes until the solenoid cools down enough.
Jul 21, 2008 | Maytag Washing Machines
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
