Hi there, I have a HE3t kenmore front load washer. I press the wash cycle I want and the cycle light blinks , the door won't lock and it will not start. Could it be the door latch is broken? Thank you, Christine
  • Christine Dumond Jan 01, 2011
    Hello Daniel,
    Would it be an easy repair for me to attempt,purchasing the part myself?
  • Christine Dumond Jan 06, 2011
    Daniel,
    Thank you, I ordered the part and I will feel impoweredmif I can accomplish this repair....you are great !
  • 4,323 Answers
Hi
Yes Christine....it is either the door latch that is broken or the door lock-switch assembly that is bad and should be replaced. Before replacing you can blow compressed air on them so that if dirt is stopping it from functioning it is removed. Hope this helps...
Daniel
Posted on Dec 31, 2010
  • Daniel Scott
    Daniel Scott Jan 01, 2011
    Hi Christine,
    There is some disassembly involved in this repair, if you would be able to do this then I would suggest you to buy the latc and replace it. Remember to unplug the washer first.
    Door assembly is easy to replace, however to replace the latch you would need to remove and reinstall the door boot spring. You would need a screwdriver and a pair of needle nose pliers. Please check the below pictures, they would be helpful in replacing the door latch assembly.
    Door Latch Assembly removal
    Door Latch Assembly removal link 2
    Door Latch Assembly removal link 3
    To reinstall the door spring, start working in the clamp on the opposite end of the spring and working evenly around both sides. Pull outward on the clamp to expand the spring as you work your way around the opening. You would need a great amount of force to work this clamp back onto the washer door opening. Please wear gloves to protect your hands. Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Daniel Scott Jan 06, 2011
    Thanks...post back if you need further help.
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer wont start
is the pin on the door switch there?
Oct 19, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
