Question about Whirlpool LSB6200KQ Top Load Washer
Whirlpool Wahser top loader
Hot water stops filling in the tub about 1/4 full
  • Anonymous Jul 21, 2008
    I have a whirlpool top load washer--i do not know the model. the #'s I have are 3957403 S2. When it is washing when it changes into another gear it pops so loud you can hear it in 2 roooms. You can also hear it agitating two rooms away. ******* my clothers.Dealer says nothing is wrong.
    It also only fills up with hot water about a fourth full. the
    dealer says that is a government thing to save energy.
    Washer is about 3 months old.
Possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Posted on Jul 15, 2008
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
Whirlpool - hot inlet hose shaking badly when filling water
check to see if the screen is clogged were water hooks up to back of michine
May 11, 2012 | Whirlpool Washing Machines
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water fills machine but won't shutoff
ekrok, you are going to have to change the fill valve. If water is still filling when the unit is unplugged, that means the valve is stuck open. This is not a hard fix. You will have to remove the screws on the top in back. Should be three. If this is a GE you will have to remove the front header. Three screws in back of the front header. Now the top will slide off toward the back The valve is easy to get at. Get your part at a local appiance parts store or order it from repairclinic.com. Change it out and this will be a done deal, Catriver
Mar 07, 2009 | Whirlpool GHW9100L Front Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
