Question about Amana ABD2233WH
Compressor stoped working is there a way to reset it
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
2004 chevy blazer ac stoped working and if the ac is turned on it stoped the engine abruptly, the pressure on the low pressure port without the engine on reads high at 150psi which is the red danger zone...
I would suspect you have a bad A/C compressor. When you engage the A/C, the clutch locks up the pulley which kills your motor from the drag on the belt. Replace the compressor, evaporator and valve, then recharge system to 55 psi.
Jun 11, 2011 | 2004 Chevrolet Blazer
My maytag refigerator mtb2656g stoped working and will not get cold only the light works
replace the ptc overload relay on the compressor as this component helps start and protect the compressor from overload,simply unplug and plug in a replacement
Jan 09, 2011 | Maytag MTB2656G Top Freezer Refrigerator
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My compressor for the air stoped working is there a fuse
there should be a fuse, but if the freon is low the compressor won't work either
Feb 26, 2010 | 1999 Ford Expedition
I have the Ingersoll Rand Model # DD2T2, WAS WORKING GREAT, NOW IT HAS STOPED WAS THROWING BREAKER IN SWITCH BOX NOW IT HAS STOPED ALL TOGETHER, MOTER CAN BE TURMED BY HAND BUT WILL NOT RUN AT ALL.
If the motor turns by hand, but the breaker is tripping does not preclude a bad motor. Could be nothing more than a capacitor on the motor itself. If the breaker you speak of is on the unit itself, could be bad. If it is in the electric panel, motor capacitor is the first place to look.
Jan 16, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
Started clicking about three days ago then stoped working compressor dose not turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The noise you hear is probably the klixon cycling because the compressor is hot. This happens when the condenser gets plugged or the condenser fan fails. This leads to a compressor failing which is probably what has happened to you.
Good Luck,
Gilshultz
Nov 29, 2009 | Aspen Refrigerators
Admiral SAC224GB Fridge freezer has stoped working
when did this happen... could be your compressor out on overlaod... leave it for an hour or so try them, if not your compressor could be gone.. or fingers crossed its just the start capacitor for the compressor...
Nov 11, 2009 | Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
I have a Samsung side by side refrigerator RS2533SW and it stoped cooling both sides. I already tried to reset it. That did not help the fan is kicking on an off. Do you have an Idea. Thanks
check to see if the fan and compressor in the back conme on first. if they do then shut the unit off and remove the back panels inside and thaw out the ocils.
Feb 02, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Amana ABD2233WH Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
