My crosley record player just doesn't turn on at all. I was listening to it and the music and power just randomly got fuzzy and died. The wall outlet is fine.
  • 6,771 Answers
From your description it sounds like the power supply is the problem, this is a job for a tv tech, and I would ask for an estimate.
Posted on Dec 31, 2010
The unit will not power up, it is plugged in to a live outlet. Is there a fuse or a reset?
FAQ: Blu-Ray, DVD and DVR / DVD Recorder ... - Toshiba
https://support.toshiba.com/support/viewContentDetail?contentId...
ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
Jan 11, 2016 | Televison & Video
Crosley record player will not turn on and i don't know where to start with troubleshooting it. I have tried different ac adapters and doffeeent outlets with confirmed power.
It seems like you will have to open cabinet and find your power in and check with volt meter to see if your infect getting power there. Also check fuse to see if its blown that can be done by putting your volt meter on ohms and make sure there is no power to the unit then go across fuse to check continuity if these is no continuity then
Mar 28, 2013 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Brand new just got it today... the tone arm goes to quickly across record and music ends up fuzzy and inaudible
You need to increase the weight on the end of the arm to apply more pressure to the stylus. It will either be a screw or you just turn it. If there are numbers on it try it around 2.
Aug 04, 2010 | Crosley Traveler Turntable
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
When I turn on the record player on my Crosley, the digital display reads "line". No sound comes from the speakers unless they are turned all the way up. And then it sounds tinny and fuzzy. HELP!
Seems like the wrong input source has been selected. The gain on the LINE input is much, much lower than the PHONO input. Try changing the source knob to PHONO. Dont forget to lower the volume before you do this.
Jun 27, 2010 | Crosley CR248 Turntable
Crosley music centre has fault on record player due to turntable not working
If the unit is belt driven, (sometimes hidden) that is common cause of turntable failing to turn. Either belt comes off or is deteriorated.
Apr 27, 2010 | Crosley CR711-BK AutoRama Retro Turntable...
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
My record player won't turn on
plaese change the power cable and check the main fuse
May 22, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
47 people viewed this question
 Grubhead
Grubhead
