Question about Connectix Virtual PC Windows 98 6 Full Version for Mac
I installed a Windows 98 version of Virtual PC on an old Apple iBook. I need to share a folder on between the PC and Apple desktops in order to move data created on the PC side. So I created a folder on my Apple desktop, and in the PC environment I designated that folder as a Shared Folder using the Preferences dialog box. Windows recognizes that shared folder as a generic F: drive. Unfortunately, whenever I try to move PC data into that shared folder, I get a "drive not available" error message. How can I remedy this, please?
  • rcr153 Jan 01, 2011
    Thanks for trying, but I accidentally stumbled onto my own solution. After instructing Virtual PC to share the desired folder located on my Mac desktop, I restarted the computer out of desperation ---- and presto, the shared folder immediately became accessible.
    President:
  • 1,851 Answers
Try to create a folder at the root of the c: drive. This means that the folder has to be not at any desktop or at any other folder but just in the c: drive.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jan 01, 2011
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Is there any driver, program or software fix that will allow me to load my "Intel Create & Share Software on my Windows 7 Dell Inspiron 530?
The Intel Create & Share was written for Windows 2K and XP and not updated. The workaround is to use a computer (second machine, dual boot or virtual) with XP installed.
If you have Windows 7 Pro or Ultimate or update to one of those versions, you may be able to run a virtual XP computer for free. Download from Microsoft and install in order the Virtual PC program and the XP mode software. Install the Intel Create & Share program in XP mode as if it is your only OS. (Note: you can't have hardware installed on the virtual and real computer at the same time. To share files you will need to save them to external media (USB or optical disc).)
Other virtual computer programs are VMWare and Parallels. For the other options, you will need a licensed version of the older Windows OS.
I hope this helps.
Oct 09, 2011 | Dell Computers & Internet
Does the Design Studio for Plastic Canvas work with Windows 7? I bought the item on Amazon, and the description stated Windows 95/98 and later, but the box only states Windows 95/98. The seller could not...
First what version of Windows 7 are you running? Click on Start > Control Panel > System and Security > System and read the title of your OS. If it ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version. Next which version of Design Studio do you have? If you have version 2.0, that is compatible with XP and Vista (not x64).
If you use a 32-bit version of Windows 7, you may be able to get it to work with the compatibility mode. Right click on the installer on the CD and choose Properties. In the Compatibility tab, set the "Run this program in the Compatibility Mode" and choose an older version of Windows (try XP first). Then right click again on the installer and choose Run as Administrator.
However, it will not work with the 64-bit version due to unsigned drivers and other issues.
There are workarounds if the program doesn't work in the compatibility mode. You need an older version of Windows running. This could be on a physical second computer, a dual boot system or a virtual computer. If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can use a virtual version of XP for free. Download and install Virtual PC and the XP mode from Microsoft in order. Then install your Design Studio in the XP "machine" as if it was your only computer. The only restriction is that you can not share your printer or files under XP mode and Win 7 at the same time. You will need to uninstall the printer and reinstall it under the other OS or transfer the files to external media to share them. Other virtual computer programs are Parallels and VMWare. For these virtual computer, the dual boot, or the physical second computer option, you will need a licensed version of the older Windows OS.
The documentation and an update are available here: http://www.plasticcanvassoftware.com/ . The update is in the Customer Service section.
I hope this helps.
Aug 16, 2011 | M & R Technologies Plastic Canvas Design...
Sonic the Hedgehog CD PC version Windows 7 error. After installing the original gold colored Sonic the Hedgehog CD, and the patch for the program, Sonic CD loads the intro screen, then freezing, and a...
Hi, welcome to FixYa!
Forgive me, but I remembered that Sonic the Hedgehog a rather very old program, which is designed to be running in Windows 9x/ME. I bet that's why it's demanding an MCI driver because it's not compatible with Windows 7.
There are 2 solutions for this.
First choice is you can try to use compatibility mode to run this program. Right-click on the .EXE file of the games (or you can use also right-click on the shortcut on Desktop or Start menu), then go to Compatibility tab, check "Run this program in compatibility mode for", then choose "Windows 98 / Windows ME".
Second choice, you can use VirtualBox, install Windows 98SE or ME on it, and then install the DirectX, remember to install VirtualBox guest addition as well, configure Shared Folder so your Virtual Machine can access to your host OS, then install the game and played it inside your Virtual Machine.
I hope my solutions are working. Thanks for using FixYa!
Jul 06, 2011 | Computers & Internet
Hi i buy a ceble that parallel to usb but my pc unkhnun my printer ... can you help me?
You need the POSJet driver from this site: http://www.transact-tech.com/tsg/1000drivers.html . Extract the files from the zipped folder (right click and choose Extract All) and then go to Devices and Printers (Start > Devices and Printers). Use the Add a Printer Wizard to install the printer and it's drivers (so remember where the folder location for the extracted files). The first zipped file is the basic driver and at the bottom of the page is OPOS driver. Note some of the drivers are not available for Win7 64-bit OS versions.
If you need those drivers and have the 64-bit OS, you need to use a work-around. The option that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Apr 27, 2011 | Ithaca POSjet 1000 InkJet Printer
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Apr 11, 2011 | Broderbund Print Master Silver 16.0 for PC
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
I purchased Hebrew Tutor and cannot install it on my Windows7, 64-bit computer. Please help.
Unfortunately, the Hebrew Tutor from QuickVerse was written for older Windows OS versions. It supports: Windows 95, 98, ME, 2000, XP Home, XP Pro, or NT 4.0. The changes in the Windows OS over time has made the installer totally different and the program isn't signed for a 64-bit OS. http://www.quickverse.com/shopfiles/product_details.asp?ID=41011 has the support details.
There are two possible ways to work around the issue. The first is to try to install the program (and then run it) in the compatibility mode. This may work but often doesn't. Right click on the installer (from the CD's directory) and choose Properties. Then go to the Compatibility tab and chose Run this program as compatible with XP. Save and close the properties box. Then right click again on the installer and choose Run as Administrator. If it installs, repeat the compatibility process on the program itself.
The solution most likely to work is to use a computer with the compatible OS versions. This could be a physical second computer, a dual-boot machine or a virtual computer. If you have Windows 7 Pro or Ultimate, you can run the virtual computer with XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. For other setups, you will need a licensed version of the older Windows OS. Virtualization packages include Virtual PC, Parallels and VMWare. Then install the Hebrew tutor as you normally would to an XP computer. (Note: virtual computers do not share hardware with the real computer. You can only install a printer to one machine at a time. You can share files by saving them to external media (optical RW disc or flash drive for example).)
I hope this helps.
Feb 21, 2011 | Computers & Internet
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
Folder with blinking question mark in it after start-up
Folder with a blinking question mark means a missing system folder, in other words there isn't an OS installed. To fix this you need to boot from the OS X installer CD. With the OS X installer CD in the drive, hold down the C key on your keyboard when you start your mac. This tells the mac to boot from the optical drive (i.e. CD drive) and load the OS X installer. From there just follow the onscreen instructions to install OS X.
Also, you should be aware that the ibook is not compatible with Windows XP. Only the newer “intel macs” of the past few years are compatible with XP. Your mac predates Apple's transition to intel processors and Windows XP compatibility on the mac platform by a few years. This is why your Windows XP CD didn't load on it. The ibook is Mac OS X only.
It only runs on Mac OS X however it is compatible with newer versions of the OS. 10.2 jaguar is kind of old and a little buggy. You may want to consider installing 10.4 Tiger for improved stability and performance. Avoid the newest version (10.5 Leopard) as it is geared towards newer and faster machines.
Hope this helps. Enjoy your mac
Feb 03, 2009 | Apple Computers & Internet
Connectix Virtual PC Windows 98 6 Full Version for Mac Logo
94 people viewed this question
Top Connectix Computers & Internet Experts
David Payne
David Payne
Are you a Connectix Computer and Internet Expert? Answer questions, earn points and help others
