Question about ViewSonic N3752w 37 in. LCD TV
When I use the HDMI inputs the picture is predominately pink. The cable and component video inputs work fine.
  • warrenforthe Dec 31, 2010
    The manual does not mention anything about a reset nor did Viewsonic support when I talked to them on the phone. I just looked for a reset switch hole on the TV and could not find anything.
    Warren
  • warrenforthe Jan 01, 2011
    Which particular response # in the A/V forum has the information to help me with my TV problem?
    Thanks, Warren
    Master:
  • 691 Answers
Book should tell how to do a hard reset or factory
Posted on Dec 31, 2010
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
My ps3 seems to b working fine but i cant see anything. no matter which tv i plug it into it says that there is no signal
Hi aztecruler12,
For you to be able to see a picture on the screen you need to make sure that you're on the right input. Inputs on your televsion depends on the cables that you are using. PS3 supports HDMI and Component Cable (Blue/Green/Red). If you're using HDMI Cable to connect the PS3 to your TV then you need to select HDMI Input and if you're using a Component Cable it should be Component Input. To change the input you need to use the original remote of your television. Look for Input or Source button and select the input depends on your cable.
Rate me if this helps so i can help others. Thanks for using Fixya.
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
The picture goes out on the TV but the sound still works. If I turn it off and then back on, it usually works OK for a while then does it all over again. I took it into a shop and they said that it was...
He was wrong... HDMI is just an audio/video format for high quality video and sound. That cable also contains the sound that goes with the picture. If it has sound but the picture is not there then the HDMI cable is probably OK. A simple way to trouble shoot that is to use a different input. For example Component Video. You will need a different cable for that. It only contains the picture (three wires), then change the input to component video. That's a menu setup. If that restores normal operation then your video is just fine and probably the HDMI cable is fine. The trouble may be in the connections behind the jack on your TV.
They are subject to mechanical stress when the plug is inserted and removed. They should be fine but if the connections weren't perfect from the factory they can cause microscopic cracks that will show as things like no video or intermittent video. You can bypass that connector by using a different audio/video input. If that fixes the problem then leave it that way. If it doesn't it's still likely to be a cracked soldered connection but elsewhere in the set.
Zashiban
Jun 23, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
Open Questions:
See all ViewSonic N3752w 37 in. LCD TV Questions
ViewSonic N3752w 37 in. LCD TV Logo
175 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
