Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I have a model 1697-M and the shampoo is not mixing with the water. Help
5 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: Bissell shampooer 1697-W. Will not dispense water
That means that the pump belt is worn and needs to be replaced. Here is the belt you need and a manual you can view:
Bissell Proheat Belts and Manual
Posted on Dec 14, 2009
rustysheriff
  • 344 Answers
SOURCE: mixing of shampoo
http://dl.owneriq.net/8/867be65f-e5bd-4066-9792-1b8fb588c29b.pdf
Posted on Apr 14, 2010
  • 50 Answers
Follow the directions on bottle of carpet shampoo and mix it another container according to the directions. Then fill your Bissell 1400-5 solution tank to the line. Replace the solution tank and use the machine.
guru_fixya
  • 944 Answers
SOURCE: Bissell - Model 1697 -
http://dl.owneriq.net/7/7e477b7e-4440-49cf-a219-b68d301549e3.pdf
This diagram will help you see the diagram plus the part assembly no and place it accordingly.I have also given link for Bissell - Model 1697 so you can use it more trouble shooting and where to assemble the parts.
01. Upper Handle Assembly - Slate Green **FNLA
01. Handle Assembly - Mean Green **FNLA
02. Spring - Push Rod 2108422
03. Push Rod with Spring 2147511
04. Trigger - Grey 2139168
05. Handle Assembly 2144406
07. Valve Assembly 2109592
09. Wire Harness 2104446
10. Lower Handle Back - Mean Green **FNLA
11. Handle Bushing **FNLA
12. Switch - Power 2108827
13. Cord 2102883
14. Tool Caddy 2146752
15. Cord Wrap 2131154
18. Axle 2100170
19. E-Ring 2106215
20. Wheel 2139754
21. Extruded Gasket - .136"X32" 2103418
22. Window Gasket 2104052
23. SmartMix® Bottle (Includes Cap) 2101785
24. SmartMix® Cap Assembly 2101795
25. Autoload Gasket 2036679
26. Diverter - Grey 2136988
27. Flow Indicator Assembly 5556503
28. Diverter Gasket 2114054
29. Diverter Knob Assembly - Grey 2145170
30. AutoMix Knob - Grey 2105108
31. Main Housing - Mean Green **FNLA
31. Main Housing - Slate Green 2145017
32. Flow Indicator Base 2100489
33. Floor Nozzle Window 2149871
34. Spray Tip (2 pk) 2106107
35. Connector T 2102602
36. Arm Retainer - RT & LT 5559113
37. Brush / Pivot Arm Assembly - 4row 2101157
38. Brush Belt 150621
39. Flow Indicator O-Ring for Powersteamer® Series 2106214
40. Base Assembly - Non-ClearView with 4 Row Brush **FNLA
41. AutoMix Assembly 2100107
42. AutoMix Piston 2108722
43. Motor Duct - Short **FNLA
44. Gasket - Short Duct 2104050
45. Belt Access Door 2132992
46. Motor Cover 2132984
47. Inner Motor Gasket 2104056
48. Motor Intake Gasket 2104051
49. Vacuum Motor 175972
50. Detent Lever 5559102
51. Elevator Lever with Springs LT & RT 2000010
52. Pump 2107181
53. Pump Belt 2150628
54. AutoLoad Receiver 2140710
55. Upholstery Hose Assembly - 8' 2153163
56. Tank-in-Tank Assembly 159043
57. Tank Lid Assembly 154439
58. Tank Handle 2034435
59. Lint Screen 2133501
60. Baffle & Bladder Assembly **FNLA
61. Baffle with Float 2130213
62. Float Assembly 2140325
63. Bladder 2100315
64. Bottom Tank Assembly 159041
65. Screw #6 x 3/4" - 6pk 2807075
66. Auto Load Assembly 2107041
67. Autoload Gasket 2036679
68. 3" Tough Stain Tool Assembly 2159155
70. 4" Upholstery Tool 2036653
71. Brush - Upholstery Tool - 4" 2030966
72. Turbo Brush 2036652
73. Crevice Tool 2036655
74. Pre-Treat Wand 2149142
75. Bare Floor Tool 2149131
Posted on Sep 05, 2010
How do I get the Shampoo solution tub unclogged so it mixes with the water to clean my carpets.
You can try adding hot water, but your best bet is to remove the tank and hose and flush them well with hot water to clean them out.
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
http://www.bissell.com/searchresults.aspx?searchtext=1698&mode=userguides
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell shampooer 1697-W. Will not dispense water to shampoo carpets....
Dec 13, 2009 | Vacuums
Bissel Quicksteamer leaking
Hi there SmartAlec from NelsonVacuums.com.au here. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
Jun 14, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
48 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
