Question about MPC Computers Computers & Internet
To put acer aspire m1640 back to factory settings
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
jamespcastle
  • 128 Answers
SOURCE: acer m1640 factory restore
Format the drive, then install an operating system such as xp, or windows 7 .... it should install most of the correct drivers. You may have to go to the manufactures website to find the exact drivers for the video and sound cards., but that should pretty much return it to factory settings. If you are really picky and have the bucks, you can contact ACER for the original disks.
Posted on Apr 22, 2010
Nileshlp
  • 67 Answers
SOURCE: how do you put acer aspire 9300 back to factory
press ALT + F10 button as soon as PC startup and run recovery console from there. follow the steps to restore PC to factory settings.
Posted on Jun 15, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Want to put laptop back to factory settings it's a acer aspire 5359
Hi Debra
This will describe how to reinstall the Operating system on your computer.
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Bud
Posted on Oct 31, 2012
How do you get the CMOS back on the Acer Aspire M1640
If you can enter the BIOS, by pushing either F2 or the Delete key after starting up the computer and seeing the first splash screen, you can reset the BIOS to factory settings. If you cannot enter the bios, in order to reset the CMOS, you must open the tower, look for the small CMOS battery (small watch style battery) and look for a set up 3 pins near the battery. There will be a jumper on on two of the pins. If you remove the watch battery and move the jumper over to the other two pins, replace the battery. Then remove the battery again and place the jumper back in the original location and replace the battery.
This process will reset the CMOS. You must also be sure to unplug the power cord from the tower before starting this process. Be sure the watch battery is not dead or the settings will not hold. So, if you're not sure, replace the watch battery.
If you found this information helpful, please remember to leave positive feedback.
Brian
Feb 05, 2011 | Acer Aspire M1640 Refurbished Intel...
I need a driver for my acer aspire m1640
Download Acer Aspire M1640 Chipset & AHCI SATA Driver For Windows XP Description: Intel Chipset and AHCI SATA Controller for Win XP
Download: Chipset-and-AHCI.zip
Download Acer Aspire M1640 Audio Driver For Windows XP Description: Audio Driver for Win XP
Download: Audio.zip
Download Acer Aspire M1640 Network Driver For Windows XP Description: Wireless WLAN Wifi, Modem and Ethernet Lan Card Driver Package For Win XP
Download:Wireless-Modem-Lan.zip
Download Acer Aspire M1640 ATI Graphics Display Driver For Windows XP Description: ATI VGA Graphics Display Driver For Win XP
Download: Part1: ATI.rar.part1 Part2:ATI.rar.part2 (Download both parts and extract using winrar)
Download Acer Aspire M1640 Nvidia Graphics Display Driver For Windows XP Description: Nvidia Geforce 7050 VGA Graphics Display Driver For XP
Download: NVidia.zip
I hope this information will be helpful. Thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
Acer m1640 factory restore
Apr 22, 2010 | Acer Aspire M1640 Refurbished Intel...
What buttons do u press to format an acer desktop
Well i mi8ght be wrong on thid one, but i am going to go out on a limb and say None. If you want to restore to factory original you will have to go into the recovery system and see restore point from way back when you first got the computer, otherwise you need the recovery disks from acer if that model came with them, then you will have to format the drive and reinstall all the programs including the operating system. Hope this helps.
Mar 12, 2010 | Acer Aspire M1640 Refurbished Intel...
J'ai un pc acer aspire m1640 et j'arrive pas instaler xp
Cet Acer a un disque dur SATA - XP ne peut le reconnaitre pendant l'installation sans le driver, Tu peut le trouver ici (avec tout les autres)
http://www.getpcmemory.com/drivers/download-acer-aspire-m1640-desktop-windows-xp-drivers/
Decompresse-le e brule-le sur un cd - quand (pendant la installation) tu sera questionne de lui met le dans le lecteur.
Feb 21, 2010 | Acer Aspire M1640 Refurbished Intel...
Restore to factory default
Most Acer M1640's can be restored to factory settings using the following method:
1. Start with the computer off.
2. Power on the unit, this should cause the Acer POST screen to appear.
3. During the Acer POST screen, press and hold the Alt key on your keyboard, and tap the F10 key on your keyboard.
4.If timed correctly, this should cause the unit to go to a black screen that says "Windows is loading files...".
5. After the "Windows is loading files" screen you should be in Acer e-recovery management. At this point follow the on-screen instructions to restore the unit to factory defaults.
Oct 08, 2009 | Acer Aspire M1640 Refurbished Intel...
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
Carnt start pc
Go to BIOS and see if there is a Hard Drive test utility.
If yes, - test drive. It might be bad.
Mar 20, 2009 | Acer Aspire M1640 Refurbished Intel...
Drivers for Acer Aspire M1640
Hi Max,
You have to try the Acer website for the latest driver sed.
Nov 27, 2008 | Acer Aspire M1640 Refurbished Intel...
Computers & Internet Logo
71 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
