Question about Ovens
I have a JennAir Model D156 that I recently replaced the bake element. When this element went out it also tripped the breaker. When turning on the oven, the display states that it is pre heating, but does not. Is there any other elements that could have blown at the same time, if so, which one(s) and how to test if these are good or not?
  • gnorthcu Jan 03, 2011
    I have ordered an oven temperature sensor and am currently waiting on the delivery of this part.
    I will let you know as soon as I replace this part
    Thank you for the follow up.
  • gnorthcu Jan 04, 2011
    OK thank you
  • 4,323 Answers
Hi
The issue seems to be with the oven temperature sensor that has blown same time with the element and should be replaced. However, before replacing it you can test it for 1100ohms and replace if it reads more than 1100ohms. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 31, 2010
  • Daniel Scott
    Daniel Scott Jan 04, 2011
    Hi
    Check the sensor when it arrives for 1100 ohms with multimeter before you install it. Let me know if you need more information.
    Daniel
  • Daniel Scott
    Daniel Scott Jan 07, 2011
    Alright
Electric range drawing too much current
Are the top and bottom elements not supposed to come on when in bake mode? Check your instruction manual. The circuit breaker will not affect how your oven works. If the CB is tripping then maybe the circuit is not of a high enough rating to cope. Again check on the load that the oven takes in the instruction manual.
Nov 27, 2014 | Ovens
Oven not heating properly
most common problems:
1. calrod unit not working(heating element) easy replacement
2. breaker tripped.(sometimes a double breaker will only trip one of the circuit breakers so you end up with half power)
good luck
Jul 19, 2013 | Whirlpool Ovens
I have replaced the baking element on our Jenn Air oven for years. However, I have recently put in two replacement elements and they both did the same thing...the element did not warm up at all, and when...
Sounds like you have a bad or loose wire on the element plug. If you could post the model number of the unit I will see if I have the service manual for your range.
Sep 30, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Burned out element
When the element burned in 2 iot may have tripped your circuit breaker.
Check your breaker box and look for a 40 or 50 amp breaker and flip it off and then back to on. If this doesn't help then a tech. may need to be called for service.
May 05, 2007 | Maytag CWE4800A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
