Question about Casio PRG-40T-7 Pathfinder
Casio Protrek PRG-70-YT
I have a Casio with a problem.
It has barometer, thermometer, digital compass, altimeter.
The Barometer and altimeter stopped working properly when I changed the battery.
I changed it, I did reset it (using the AC and (-) sign thing) but then when I try to access ALTIMETER or BAROMETER i just shows blank lines - - - - where the values should be.
I tried setting new values (reference) but when I press the button, OFF just blinks but nothing happens when I try to press the side buttons to set a value.
Even more, the altimeter shows _ - - - - , which in the manual is described as "out of range".
Do you have any clues ?
Please don't tell me to take it to repair place, in my country there is no such thing, maybe if you had this watch you can help me.
Thanks a lot
laubzz@gmail.com
Wait until the battery is full reloaded
Posted on Aug 03, 2008
How to switch altimeter indication from feet to meter
If you're using an altimeter, they're always in feet. Standard aeronautical practice.
Mar 14, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
I dont know how to turn the alarm off on my casio protrek triple sensor watch and it alarms each midnight!?
Scroll through the screens until you get to the alarm screen and select the barometer button to turn alarm on and off.do not go into edit mode.
Sep 03, 2011 | Casio Protrek Triple Sensor Prg 110T 7VDR...
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
I have an older model casio watch with thermometer, barometer, compass; Is there a manual on how to acces the features?
you should be able to get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Dec 23, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
I need an instruction manual for a Casio Pathfinder watch. I show PAW-1400T-79VCR on the box as the number. Can u help me find one? It has a solar battery, digital compass, altimeter/barometer and...
you can get
watches;
Accept terms
Aug 13, 2010 | Bulova Watch
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Barometer ERR message on Casion 2271
here is the link for very complete manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2271.pdf
Download it and follow the instructions how to set and reset the altimeter and other features of your watch. Use zoom or magnifying tool, as the document originaly has tiny script.
Do not forget to rate please.
Feb 09, 2009 | Casio PRG-40T-7 Pathfinder
Casio protrek watch altimeater and barometer only showing ----- lines temp and clock are fine I have comparable problems With me it is even stranger. My barometer works still more or less, as long as I...
The best would be to start with the battery check (must be full power) and full resetting of the watch.
Here is the link to user manual download page:
world.casio.com/wat/download/en/manual/ - 23k - Cached - Similar pages
If all this do not help- find your nearest watchmaker and ask for help.
Dec 21, 2008 | Casio Protrek Triple Sensor Tough Solar...
Casio PRG-40T-7 Pathfinder Logo
1,381 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
