Question about Dell V313w AllInOne InkJet Printer
All photos, when printed have stripes/bands, especially noticeable on blue sky. Any way to improve, or is that just a problem with the model?
  • 6,826 Answers
Change the ink jet cartridge for the blue or other colors. Make sure you align the print heads through the printer control panel or 'service' area of the printer on the computer.
If changing the ink jet cartridges and aligning doesn't help, then the printer is at fault. Usually, though, servicing these two things will rectify things.
Good luck with this repair.
Posted on Dec 31, 2010
Roland SP 540v with Eco Sol Max ink. ... When printing large solid colors, especially blues and light blues, there seems to be an ink supply weakness that shows up in soft-edged stripes in the direction of...
Inhae had similar issues, I corrected it by slowing down the print rate to 250mm per sec and also doing a calibration to the messy used if all else failed calibration wise I used textile heat transfer profile for printing on both banner and vinyl hope this helps
Sep 21, 2010 | Office Equipment & Supplies
Stripes in coloured photos
This is possibly banding and can be caused by blocked injets or a faulty printer head. It is not seen on print because the spray pattern is grossly different on text than it is on creating pictures
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Office Equipment & Supplies
How do i stop banding on hp9000 -- i print a job of 25' long first 8' or so print passable - little banding - so i walk away for about 10 mins or so - several feet comes out thick banding lines --ex. my...
The reason for banding on the long panels (especially with solid coverage) is the high content of dissolved air in the ink. Dissolved air causes a gradual nozzle drop-out that cannot be stopped unless you do the head cleaning in the middle of the print. Unfortunately you cannot force HP9000 to do the automatic head cleaning in the middle, it can do it only at the end. Manual head cleaning is possible but it takes such a long time that it shows as stripe on a print, and the productivity suffers. Even the OEM HP ink is full of air inside. Our company did a lot of research in this area and we came up with a special ink packaging technique that ensures the ink is 100% free of air. People who tried printing with our ink can easily print 50-foot panels without any nozzle drop-outs or color shift. If you want more info please call us at 1-905-820-8833, www.solventcartridges.com We also produce portable print head recovery devices and solutions for solvent printer recovery after long periods of inactivity.
Vladimir Digital Sign Technologies www.solventcartridges.com
Feb 26, 2010 | HP DesignJet 9000 InkJet Printer
My TV Screen just turned off, but I hear the sound, have no menu.
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Photos have started to show "banding" stripes
When a couple of deep cleaning cycles don't improve your photos, it's time for a new printhead. Some nozzles may be burned out. The printhead is part #
QY6-0076-000 it runs nearly $100.00 but is the only way to restore quality printing.
Dec 29, 2009 | Canon i9900 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
The magenta & blue rollers on our Epson Aculaser C900 are printing in stripes.
quick check
1. are you running out of toner magenta and blue??
2. remove magenta and blue, shake them gently HORIZONTALY to evenly distribute the toner inside (the toner container internally has a spade that feeds the toner dust to a spongy roller then to the roller u see on the outside :) )). DON'T HANDLE THE TONER CARTRIDGE VERTICALLY ---ESPECIALLY WHEN U ARE LOW ON INK---
3. on photo conductor read my article
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
May 02, 2008 | Epson AcuLaser C900 Printer
Printer problems,
i think the heads need cleaning click start ,click devices and printers, right click on the printer image, click troubleshoot and follow instructions.
May 07, 2017 | Canon BJC 8200 Photo InkJet Printer
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Dell V313w AllInOne InkJet Printer Logo
122 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
