Question about Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White
Lasko pump motor in jetted tub comes on when switch is turned on but doesn't pump any water from jets. Unit has been used very little and is about 8 years old. Is there any such thing as priming these pumps, or can you advise me on what to do?
  • Jacuzzi Master
  • 717 Answers
You can check to make sure there is water to the front of the pump. What they use on their tubs is called flooded suction pump i.e. there has to be enough water to the front of the pump end to **** it through and push it up and out of the wet end.
fill your tub up and loosen the discharge union on the top of the pump until water starts to come out, quickly tighten the union back down and then see if you can get the pump to start pushing water.
Posted on Jan 12, 2011
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 | Pool & Spa
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
I have a jacuzzi tub in my master bath, and it has started surging through the jets in about an 8 second interval. Also I have started noticing a little bit of water leaking from under the side of the tub....
Surging is caused when the pump doesn't have enough water to push to the jets. this is usually a problem caused by air being drawn into the suction of the pump.
take a look at the jet(s) facing the suction cover.
I have seen cases where the water with the air mixed in causing bubbles gets sucked into the suction of the tub and causes the surging because the pump is pulling in too much air.
try rotating the nozzle of the jet facing the suction away from it. point it another way. turn the air control knob closed and see if that is the problem.
the only other issue that could cause this 'surging' problem is a leak in the suction line and could be the source of the water you see under the tub.
Aug 18, 2011 | Home
Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Feb 07, 2011 | Home
Jetted tub is on 2nd floor over kitchen. when jets are on water comes thru kitchen light fixture! Help!
First find access to tub,by code there needs to be access to pump motor,either built into wall or various tubs front skirt is removeable.Fill tub and run to visibly see leak,sounds like bearing assembly gaskets are leaking on pump,could possibly be a jet connection,but if it only does while running its the pump or motor assembly.Hope that helps,in the future make sure water is always above suction intakes or can lead to premature burnout of pump
Jan 26, 2011 | Home
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
No whirlpool jets
It sounds like the motor needs to be lubricated or there is debris keeping the impeller from turning without the help of a littl force. I would have a professional that deals with whirlpool tubs come and lube the motor.
Mar 20, 2009 | Home
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 | Home
Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White Logo
215 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
