Hi I have an Acer aspire L100 and it keeps turning itself off, It has been doing this randomly for the last week or so but from today as soon as You log into a user name and it loads up then it just shuts down straight away, I have tried using a hoover to **** the dust from the fan as i thought it might be overheating but it is still doing it, any ideas what the problem could be?
  • jules2909 Jul 09, 2008
    Thanks will defo try that, I'm sure its over heating cos was ok first thing this morning for 2 hours then kept turning off again, have just switched on after leaving it off for 3 hours and has been ok for 10 minutes so far,
    Problem Solver:
  • 10 Answers
Try logging in under Safe mode or better yet go in the bios mode and depending on your system there will be a field to check the CPU tempature Leave it in Bios for ahile and see if the temp goes up or stays steady. Also boot it up with case open if possible. Watch the fans and see if they are all moving at aq descent speed
Posted on Jul 08, 2008
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
    this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
    May 14, 2010 | Acer Aspire L100 PC Desktop
    Ok....do you think its worth changing the fan before i reinstall the operating system. as soon as i turn on the heat sinkk starts to get hot. the battery for the motherboard was alsoo completely dead, soo...
    yea those are the disks i'm talking about, and if your cpu fan is not working then i would get that replaced today if possible otherwise you will damage your processor and have to purchase a new one
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    I have an acer aspire 5920 notebook
    Try This:
    http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
    Download Malwarebytes to your desktop, Boot your computer into safe mode and run a full scan. Remove what was found.
    This is how it works:
    http://www.malekal.com/tutorial_MalwareBytes_AntiMalware.php
    Feb 09, 2009 | Acer Aspire 5610-4648 Notebook
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Acer l100 cuts out for no reason
    I suggest to remove the program for itunes, i think it did make a mistake  to the operating sistem
    Dec 06, 2007 | Acer Aspire L100 PC Desktop
    Computers & Internet Logo
    96 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
