Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Hi i have a L118 with only 76hrs on it and i think the timing is off hard to starts back firing and than starts and runs pretty good to cut lawn how do i time it?
  • Douglas Heath Jan 01, 2011
    hi i have a john deere 22hp v-twin L118 with only 76hrs on it. it is hard to start and back fires but it starts and runs ok to cut the grass i took the air cleaner off and turn it over and flames come out and back fires than start new plugs new fuel filter any advice?
  • Douglas Heath Jan 03, 2011
    hi i have a john deere 22hp v-twin L118 with only 76hrs. It turns over fine but very hard to start i took the air clearer top off and flames shoot out than starts and runs good enough to cut the grass new plugs and new fuel filter any advice? thanks
  • 297 Answers
Hello, Have you or anyone done any work to the engine? The only timing is done with a key in the flywheel and the crankshaft. Your problem might be a stuck valve. You can check this by removing one sparkplug wire at a time and listen for the engine to change speeds. When you remove the one on the bad cylinder, it wont change speed. When you remove the other the mower will quit or almost quit. This tells you that the other one has a problem. The most likley problem is the intake valve. You can visually confirm this by removing the valve cover and you will see the valve in a lower position. The back firing from this condition usually is through the carburetor. Your air filter will sometimes be wet.
Hope this helped ypu to determine the problem.
Posted on Jan 04, 2011
  • 124 Answers
My name is Dane, and I'd like to help you with your problem.
I did some research and believe you have the Briggs 40CI engine. If not, disregard this complete post and repost with your correct model type and code.
I believe you will need to adjust the Valves on your engine. I don't understand why they would be so far out so soon, but that's the typical symtoms. Since it should still be under warranty, I suggest you take it back and allow a John Deere Service department adjust them.
If the warranty has already passed and you need to do it yourself, here is the way to do it.
1. Remove both valve covers and spark plugs.
2. The exhaust valve will have a steel push rod, and will be next to the exhaust port of the engine.
3. On the cylinder you are adjusting, turn the engine by hand untill you are on the compression stroke and place something long and thin inside the spark plug hole to rest on top of the piston. As you turn the engine to TOP DEAD CENTER, mark your probe you're using, where it comes out of the hole. Continue turning the engine until your probe drops 1/4 inch. That
Posted on Jan 01, 2011
  • Dane Beckett
    Dane Beckett Jan 01, 2011
    That is where you will do the adjustment for that cylinder.
    4. Loosen the valve adjustment and using a feeler gauge, adjust the exhaust valve to .007 and the intake valve to .004 and retighten the adjuster to about 60 inch pounds.
    5. Do the other cylinder just like you did that one.
    6. replace the valve covers and spark plugs and you should be good to go.
    Thanks Dane
Why won't my Honda HRX217VLA lawn mower start
Hi Duane:
I'd be thinking that it's possible that the alignment key on the flywheel has sheared. That will throw the timing out and it can't run.
Fix is pretty straightforward.
Disconnect and remove pieces until you have the flywheel exposed. Loosen the nut. Lift on the flywheel and smack down on the nut with a plastic mallett to loosen the flywheel. Then remove the nut and flywheel. Replace the key (get replacement ant any lawnmower or chainsaw service shop)
Put it back together and it should run just fine.
Cheers.
Nov 04, 2015 | Honda HRX217VKA Lawnmower
1997 jeep Cherokee exhaust manifold glows red &starts running rough cuts off hard to start once warm took off cat still have problem thinking bad gas
Sounds like you have a timing issue(firing after TDC, bad, pushing still burning fuel mix out the exhaust), so grab a timing light and check to make sure the engine is firing at the correct time before TDC. Your Cat convertor shouldn't be a problem.
Jun 03, 2013 | Cars & Trucks
Its back firing and keeps cutting off cleaned the filter
Hi: Did you hit a rock or other solid object ,Some times if you hit a hard object it will Shear or partly move the Flywheel Key and throws the timing off which will cause kick back and back firing. If it is back firing through the carburetor it is probably flooding cause by a dirty or faulty fuel jet and seat, if so clean and check the jet in the carburetor. Hope I have helped you AL
May 08, 2013 | Briggs & Stratton Garden
High Revving Honda Lawnmower
When you put the carburetor back on did you get the linkage springs put back in the correct place? If you have a governor spring off or in the wrong place it will run fast. Running at an RPM higher than the recommended one can cause severe internal damage but shouldn't cause it to be hard to start. The hard start can also be from an incorrect linkage connection
Dec 17, 2012 | Garden
Lawn mower fires but doesn't wanna run
You may have to inspect the woodruff key that is possibly worn out in the groove of the main shaft, To inspect this key way devise you need to remove the top off the mower probably 4 phillips screws off the plastic housing comes dont forget to pull out the oil stick, then removethe pull chord assembly in one piece 3 rivets need to be drilled out and reinstalled with new ones from Ace hardware when done, then remove the 3/4" nut...tap the shaft not to hard to loosen the flywheel and check to see that the keyway(woodruff pin) is worn out, go to a hardware store with the old one and buy a replacement reinstall everything and mower should be good to go.
Jul 16, 2010 | Garden
My lawnmower won't start
My first action would be to check for fire. Pull the spark plug wire and either snap an extra plug onto the wire, or pull the mower's plug and snap into the wire. Pull or try the key start, to see if the plug is firing.
If it's not firing, you'll have to look at other possibilities... eg kill switch or coil issues.
I hope this helps... Good luck!
Oct 22, 2009 | Garden
Briggs and stratton quatum 5 hp lawn mower engine will not start, firing but keeps kicking back. pulls the starter cord right out of your hand.
Sounds like your ignition timing. If the blade hit something solid while cutting it might have bent the shaft or sheared flywheel shear key. This is not hard to replace, just remove the engine cover and flywheel. If its not that, it could be inside the engine and that would be a bigger job Stephen.
Sep 20, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
343 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
