Question about Cuisinart DCC-1200 Coffee Maker
It smells medicine - Cuisinart DCC-1200 Coffee Maker
  • 85 Answers
Hello Myrnafran,
The medicine smell is usually an indication of backed coffee grounds in the system.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 06, 2009
Adjectives to describe smell
  • acrid
  • antiseptic
  • bitter
  • burning
  • choking
  • clean
  • delicious
  • fragrant
  • fresh
  • medicinal
  • musty
  • putrid
  • rancid
  • rich
  • rotten
  • salty
  • smoky
  • sour
  • spicy
  • stale
  • stinky
  • strong
  • sweet
Jan 17, 2014 | Games
Why isn't acupunture considered western medicine?
The main difference between western and eastern medicine is that western medicine is scientifically proven to work. Eastern medicine may be said by some to work but does not have the backing of real science. Since acupuncture has not been a proven method for any affliction and is not held to the same standards as scientifically effective methods/medicine, it cannot be considered scientifically sound and is therefore considered Eastern Medicine.
Dec 26, 2013 | Health & Beauty
What are some specific types of medicine balls?
Some of the varieties of medicine balls include: leather medicine balls, soft gel medicine balls, medicine balls with grip, air filled medicine balls medicine balls with handles and medicine balls with a rope attached.
Aug 05, 2012 | Exercise & Fitness
My GE Dehumidifier smells funny
You need to clean the filters every other week and I clean the bucket everytime I empty it with either mean green or water and vinegar
That should help it alot
May 01, 2012 | GE Dehumidifiers
Metallic or medicinal odor from fridge
Sounds like the smell of fruit that has gone bad. There is no odor per se that a refrigerator or freezer "manufactures".......Freon is sealed and is odorless--that's the only kind of fluid/chemical that a fridge condensor circulates. Look for some food that has gone "south" first.
Oct 08, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
Medicine
You don't. There are some solutions you can but for it to make sure it doesn'y get slimmy, but that's about it. It works quite well without any medicine, just works great!! Ever since I bought it six years ago my son loves it and his room gets nice and cool and he can sleep and breathe much better at night. Good luck and hoepfully this was helpful to you. Have a nice and pleasant day.
Oct 31, 2007 | Vicks Cool Mist V3500 Humidifier
Cuisinart DCC-1200 Coffee Maker Logo
64 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
