Question about Samsung P2270HD 22" LCD Monitor
My screen has a thin black line across approx. 7/8ths of the screen about 1" from the bottom - is on all stations and on blank screen without aerial
  • 6,826 Answers
I would try to replace the screen if recently purchased, under retailer's warranty. If within 30 days, Walmart, for instance, would replace, exchange, or refund money on the product.
The symptom described indicates that the screen is bad or damaged.
Posted on Dec 31, 2010
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
2 thin lines from top to bottom 5-6 in. from ends of screen.
if your set is a plasma then that can happen .. LCD screens are not known for that problem but it does happen to them also .. sometimes you can balance the screen a bit better by leaving a blank bright screen on for an hour or so ... also just playing wide screen often reduces the effect over time .. DLP type projection TVs dont normally do that but LCD and CRT type projections can .
Jun 24, 2010 | Televison & Video
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
I have a HTC 6800 that started acting funny about a week ago. At first the screen got lines across it when I would open the keyboard, then after a couple of days the srceen just froze when the keyboard was...
I had this same problem, there is a thin line of wires connecting the bottom half and top half of the sliders, after awhile it just plain wears out and will generally crack, without these wire anything on the front of your phone will no longer work. The screen is black but stil lights up a little bit and occasionally the buttons light up but its pretty much toast I'm sorry to say. I upgraded to a HTC Touch Pro 2 and am happier than ever!
Jan 18, 2010 | HTC PPC-6800 Smartphone
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Samsung P2270HD 22" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
