Question about Dayton E51 Oil Filled Utility Heater
Dayton 175k heater
Heaters run then cut off after 3-4 minutes changed filters igniter new fuel not sure if photo cell good how do u tell
  • thomas5 Nov 20, 2008
    Heater runs for a few minutes then goes to blowing smoke, we have cleaned the photo cell and ohm's show it is okay. any suggestions.
  • Anonymous Jan 22, 2009
    im in the same fuggin boat with mine..if i lift the back cover n prop about 3 inches runs fine?lak of fuel?
  • 181 Answers
The air pressure is not correct on either units.the photo cell DOES NOT look for light any more,it count the light flashes.if the flame is not in the right possition the heater will shut down....after the unit ignites the ignitor is no longer used to keep the unit working,just the fuel that is being fed to the flame ball.that's why the pressure is so inportant.......
Posted on Feb 23, 2009
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
All pro 60,000 kerosene heater wont start, igniter lights then cuts off. i cleaned fuel filter and air filter. and burner .. i dont know how to check or clean the photo cell.. any help
If you can get to the photocell, make sure that it is clean. To test it you need an ohm meter. Hook the meter to it and set the meter to read Kohm.. See what it says, then shine a light on it and see if the meter reading changes. IT should drop. If it does not, or the reading is really high, replace the photocell.
Nov 25, 2013 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Runs only couple minutes and quits . Have cleaned filters but problem persists.
It is most likely the Photo Cell. Its job is to "detect" a flame and if it is bad then it will cut the unit off so fuel doesn't continue to spray out. I also found a great web site for parts for all these models as well: http://www.bealsmotor.com/
Jan 11, 2010 | Dayton E50 Heater
Laser toyostove will not ignite
Zen,
When you ran out of fuel the filter trapped some air in the very top. You need to loosen the fitting on the fuel line right at the filter and let the fuel run of a minute. This will clear the air from the top. On the way out to the filter unplug the stove. Leave it unplugged for 20 minutes. This will clear the EE22 message. Now you can restart your stove.
Tom Hawkins
hawkins111@gci.net
Apr 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Feb 01, 2009 | Dayton (3E386) Heater
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Dayton E51 Oil Filled Utility Heater Logo
368 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
