Question about Garden
IR2130 IMPACT WRENCH WANTS TO STOP WHILE REMOVING BOLTS. IT STOPS HAMMERING.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,949 Answers
Might need air tool oil
Posted on Dec 31, 2010
I hear and feel a thump when accelerating too fast from a stop. No thump if starting slowly. No problems accelerating once car is going. What could be causing this? Thump seems to be in the rear.
Transmission mounts are worn out and most likely your motor mounts too. Pretty straight forward job to replace but sometimes the bolts holding the motor mounts will be stuck requiring an impact wrench. Problem is that there is no room to get the impact near these bolts making a lift necessary.
Apr 14, 2015 | 2005 Cadillac SRX
The best way to change the flexplate on a 2000
You need to get the car up on tall jack stands. Rent a transmission jack. Remove the transmission. The bolts that hold the flex plate are difficult to remove by hand. Use an impact wrench and impact sockets to get the bolts out. Reinstall them with a torque wrench.
Oct 15, 2014 | Cars & Trucks
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
Flywheel torque specs for a 1984 ford bronco 2 xlt
if you have an impact wrench set it on 3 and run the bolts down until the impact just starts hammering torque is set
Dec 31, 2011 | 1984 Ford Bronco II
My CP impact wrench run fine when not removing a bolt. When removing the bolt it turns it a few rounds then stops
Try a good cleaning with diesel fuel. Keep adding diesel into air inlet until the fuel comes out clean (add diesel then connect air to blow it out) . Once clean, add several drops of oil and retest. If it works better but not full power, try another cleaning with wd40 and retest. Good luck
Oct 16, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
When using the tool to loosening bolts my wrench
dont use wd40 or any of those kero basedthings in an air tool use automatic transmission fluid or buy air tool oil. the symptomyou speak of is typical of ther neoprene o/ring becoming hard and breaking up .my best advice is to take it to an airtool servic centre strange this is the second one of these in 5 minutes
Aug 18, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Change idler pulley
It's a T-40 size, but I removed the bolt by first removing the bracket holding the pulley--I assume you're talking about the alternator idler pulley, the one right below the alternator. The bracket is held in place by three 14 mm bolts which I was able to reach from the top of the engine (after removing the black plastic air tube). I then put the bracket in a vise and "buzzed" off the 14 mm nut using an electric impact wrench ($30 +/- from Heartland of America). Be careful when putting the nut back on--the impact wrench will likely be too much torque!
May 17, 2009 | 2003 Kia Sedona
Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Wrench support
impact wrenches are often misused by those who don’t know about their special needs. First of all, it is very important to be careful when tightening a nut or bolt with an impact wrench! Cross threading can occur very easily; a novice may also over-torque a bolt or a nut if they don’t know when to stop. To prevent such problems, always be sure to hand-tighten every nut or bolt before using the impact wrench; if you try to start the nut or bolt with the impact wrench, you won’t be able to feel if the threads are crossed. If the impact wrench is not torque controlled – meaning it will stop when the nut or bolt is tightened to a certain torque – you will need to go slowly, and periodically check the torque value of the nut or bolt to make sure you haven’t tightened it too far.
Aug 27, 2008 | Campbell Hausfeld 1/2" Impact Wrench
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
