Question about Pegasus Technologies Plumbing
Pegasus K300 Kitchen faucet wont spray. it will only stream. I tried to take it apart to diagnose but I cannot seem to get into the head.
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 15 Answers
SOURCE: Moen one handle kitchen faucet very low water stream
if the pressure is good with the head off then you can probably get a new head for it u shouldn't have to change the cartrige. it sounds like the head is clogged so plastic pieces in the head to help save water "water savers" it is hard to clean them i would try changing the head u should be able to find on for a moen, u buy for looks u buy it for life. take the old head with u when u go to buy a new one so they can match it up to the right one.if you can't find it and a lowes or home deptm try a plumbing supply house
Posted on Apr 19, 2009
canddplumb
  • 35 Answers
SOURCE: How to repair a pegasus faucet
I was unable to aquire a spec sheeet. I didnt know the model# or name.I did find a web site that had pegasus fausets.Fausets.com I tried to down lode the specs on 1 of there fausets.They wouldnt let me.But i did get you a customer service#1800-444-5783 .I hope this helps
Posted on Dec 02, 2009
  • 333 Answers
SOURCE: kitchen faucet spray head broke off
Home depot or Lowes
Posted on Jun 17, 2010
geo5734036
  • 528 Answers
SOURCE: My Pegasus kitchen faucet leaks
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Posted on Nov 29, 2010
For kitchen faucet Fontaine NF-RSPK the spray function is broken/inoperative.
time to replace it the internal parts are not available as repair parts
Nov 12, 2016 | Fontaine Plumbing
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
Franke Kitchen Spray Head Part # 4089. Lever on top moves it from stream to spray While on Stream Spray is leaking.... Tried changing washers 1st...then tried new aerotors... still leaking
I have the same problem. By taking off both aerators, I can see that the rubber ring inside the spray head partially disintegrated. Little pieces of rubber even fell out. I can remove the spray head (it twists off; I used a pliers and rubber gloves) but I can't take it apart and even if I did, I don't know if I could replace the rubber ring.
Nov 18, 2010 | Franke Plumbing
Since buying the house, we have always had slightly lower flow out of this faucet, but most recently flow is down to a weak stream. There seems to be no problem with the faucet head. All other faucets in...
Sounds like there is a blockage in the head try to disassemble it carefully and clean it out. Watch how you take things apart, if your recall is less than perfect take pics. with your phone or dig. camera. Good Luck
Nov 12, 2010 | American Standard Kitchen Faucet 6310 020...
Mar 08, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Spray lock button does not lock in position
sadly not much to be done there but replace the head
Nov 30, 2008 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
106 people viewed this question
Top Pegasus Technologies Plumbing Experts
Donni Steen
Don Numinen
Don Numinen
jdthefixer
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
