Question about Welding Tools
Lost ground but still feeds wire no spark - Welding Tools
  • 297 Answers
Have you made sure that the ground clamp is on good clean metal? Even if the original contact is not a good cround, the moment the wire hits the steel ( must be clean also), the ground will spark, and complete the cicuit.
Hope this helps.
Posted on Jan 01, 2011
My Lincoln 120 mig wont weld just sparks it feeds the wire n gas but wont weld wat can be wrong wot my weldi g mechien
look for a bad ground wire connection ---in the plug , clamp, position of the ground clamp surface,cleanliness( paint, rust etc) place the ground clamp as close as practicable to the welding point
Apr 03, 2016 | Lincoln Welding Tools
Huskvarna Rancher 55 (~2000) no spark
could be in your switch. the ground wire needs to be attatched for new coil to work
Aug 26, 2014 | Garden
How do you hot wire the coil on a 1999 chevy ws10 zr2 4.3 v6?
not possible without a device that pulses the coil on and off, unless you mean you just want to test it? I am confusing cars but most cars now have a dual feeding system or coil over each combustion chamber. You can feed a coil 12v and once you release the gound it will fire but, the coil needs to be attached to a spark plug and the sparkplug needs to be touching a ground source to watch the spark occur after the release of ground.
May 24, 2014 | Chevrolet S 10 Cars & Trucks
Car wont start no spark at plugs
if distributor model check coil feed to distributot for spark this is done by grounding the coil wire. if coil module feed then check power to coil module if no power then your problem is outside the engine area in the ingition or fuses ect many possibilities
Oct 20, 2012 | 1990 Toyota Camry
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
I have a 1999 pontiac grand am and the reverse lights and brake lights work but i can not get the tail lights to work. I discovered that the reverse light on the bottom of the car is missing the connector...
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Find 3 wire connector going to lense in trunk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brown wire light green wire & black blk is grd moke sure its good, lit grn back up lights,drk Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
brn tail lights turn parking lights on & with a test light back probe connector no power to brown? ck fuse trace harness to switch wires all good bad switch if you know how to use ohm meter you could use that to ck for shorts on continuity Pin
Wire Color
Circuit No.
Function
A
BRN
9
Parklamp Feed
B
LT GRN
24
Backup Lamp Feed
C
BLK
750
Ground
Aug 30, 2009 | 1999 Pontiac Grand Am GT
No arc/ no burn
You need to inspect the ground.Where it connects to the machine, and at the end. I bet one of the connections or the wire itself is damaged.
Jul 20, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
My sp100 works,but very poor almost no spark.
MAke sure you have a good grond and a good connection between the welder and the ground cable and the ground cable and the clamp, Check the wire feed speed. Try turning the wire feed speed down. Make sure you have it on the right heat setting.
Jun 01, 2009 | Lincoln Welding Tools
No arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Apr 04, 2009 | Welding Tools
1991 Honda Civic No Spark
Excessive resistance in the wire (including breaks or shorts) or the fault is not the wire itself but what feeds that wire its power.Have you run a seperate wire from the battery to feed power to that wire yourself.?Does the car start if you do?
Feb 15, 2009 | 1991 Honda Civic
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
