Question about GE Profile Spacemaker Over-the-Range Microwave
My microwave GE Profile Spacemaker 2.0 keypad does not work, I unplugged it and reconnected it and it works at times for a while then it stops again.
  • GE Master
  • 9,085 Answers
You have a failing membrane keypad.
To help you further, I would need your brand and the full model number from the tag on the unit.
It's best to repost a new message to FixYa or contact me directly.
Posted on Jan 02, 2011
  • Mark Warnick Jul 08, 2013
    How difficult or costly is it to fix this problem? Is it something a do-it-yourselfer can handle?
  • Francisco Sep 02, 2013
    Same problem. Is there a way to order the part for replacement?
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE Profile Spacemaker xl 1800 JVM1860SD. Touchpad has stopped working.When power is turned on -get error message F3
F3 means you have a shorted membrane keypad.
The keypad is not available as a separate part, so you would have to order a control panel frame assembly, which comes with a new keypad on it.
Whether your model number is JVM1860SD001 or JVM1860SD002, the part number is WB07X10474 and a link to various suppliers is here.
They're not making these anymore, so order while supplies last.
This is a simple DIY job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and carefully move your circuit board into the new frame.
Some connectors on the relays have a lock:
Dec 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker Over-the-Range Microwave Logo
1,285 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
