Question about Viking 24 in. Professional Series VUD040 (Premium) Built-in Dishwasher
The water is not filling into the dishwasher. I have never used a Viking before and have no user manual. I think the model is Viking Professional 24-inch, SS2333. Help!
5 Suggested Answers
  • 205 Answers
SOURCE: Viking Dishwasher
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Posted on Jul 21, 2008
abhishek33
  • 1239 Answers
SOURCE: Kenmore 24 in. 17512 Built-in Dishwasher
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 12, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
appldoctom
  • 311 Answers
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Posted on Jan 24, 2009
My Viking Dishwasher is about 7 years old and it does not fill with water
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Nov 20, 2010 | Viking DFUD04 Built-in Dishwasher
The machine starts but doesn't load water; what can be wrong?
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jul 16, 2010 | Viking 24 in. Professional Series VUD141...
No water is flowing into the washer, and especially no water is spraying around inside. what can i do?
heatman101
May 31, 2010 | Viking 24 in. Professional Series VUD141...
Our garbage disposal was blocked and the dishwasher had filled with water because of the blockage. Now the disposal is fixed, but the water will not come on in the dishwasher when the cycle is started.
THERE IS A LITTLE FLOAT IN THE BOTTOM OF THE DISHWASHER THAT DETERMINES THE WATER LEVEL. mAKE SURE THAT IS FREE TO MOVE,RESET THE DISHWASHER TO THE BEGINNING AND START
Oct 02, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher won't fill with water
NEED TO CHANGE THE ELECTRIC TAP IN THE BACK OF THE DISHWASHER.
THE TAP IS WHAT THE WATER HOSE CONECTS TO AT THE BACK OF THE MACHINE.
Oct 14, 2008 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher
Apr 30, 2008 | Viking 24 in. Professional Series VUD040...
DISHWASHER WONT FILL WITH WATER IF I PET WATER IN, IT DOES PUMP OUT BUT WILL NOT FILL?
there a valve at the bottom its round moved it up and dowm may be there some debrie in it it should make a clicling sound when moving it dont foget to rate this hope it work cheers
Jan 17, 2008 | Viking 24 in. Professional Series VUD040...
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking 24 in. Professional Series VUD040 (Premium) Built-in Dishwasher Logo
89 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
