Question about Maytag Dishwasher
The Jet Dry dispenser has rusty water coming out of it.
5 Suggested Answers
SOURCE: In my GE dishwasher, the jet-dry in the dispenser
Had the same problem, opened up the dishwasher, pulled out the jet dry container and found some kind of nasty growth in it. I honestly have no idea what it is, so of course I took a picture, and then threw the whole thing away._1813.jpg
Posted on Aug 21, 2011
KOakaKO
  • 135 Answers
SOURCE: Dawn in the Jet Dry Dispenser
It may not hurt the machine, but it leaves soap on the clean dishes. You can't really remove the reservoir without dismantling the entire door. it's pretty straightforward, but takes a little time and effort. If you're not prepared to dismantle the door to get to the reservoir, you -could- try cleaning/rinsing it out with a turkey baster and a small diameter piece of plastic tubing. Just suck everything out, then fill it with rinse water and suck that out as well. But you'd have to fill it with rinse water over a dozen times to really get it clean. Hope that helps. ;)
Posted on Aug 10, 2007
falter
  • 245 Answers
SOURCE: Washer < 1 year old. Jet dry will not go in
as ur machine is still under warrenty u should go in touch with GE and have thos problem solved free of charge....
Posted on Mar 15, 2009
  • 403 Answers
SOURCE: dishwasher does not dispense jet dry. Is full all the time
If the jet dry dispenser is full, it will last you about 3 or 4 months depending on how often you use the dishwasher
Posted on Nov 15, 2011
Jet dry dispenser not working
Sometimes dishwashers become clogged with water minerals and they need to be cleaned of these minerals. White vinegar works pretty well. Place some white vinegar in the dishwasher , about one cup full, and also place white vinegar in the jet dry dispenser, and run dishwasher without any dishes in it. Maybe that will work.....
Mar 28, 2014 | Kenmore 15899 Built-in Dishwasher
Dishwasher does not dispense jet dry. Is full all the time
Nov 09, 2011 | Maytag Dishwasher
In my GE dishwasher, the jet-dry in the dispenser turned brown. I emptied it all out and refilled it with clean jet-dry, but a few weeks later it was brown again. I guess somehow dirty water is getting...
Jul 17, 2011 | Maytag Dishwasher
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
We see white all over the spoons and the bowls and not sparkilig white.
Make sure the water is 120 degrees at start up and also that the jet dry dispenser has jet dry. This aids in the clean rinse and spotting on dishes during wash, but most importaant is the water temp. Must be 120 at start up or you get an almost totally cold water wash.
May 31, 2010 | Kenmore Dishwashers
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
The dishes come out with white film on them. During the washing cycle water is not hot, it's only luke warm. I thought it was the heater but the drying cycle works well. Is it all connected to one heater?...
Are you having any issues with your water heater at all. Make sure to run the water at the kitchen sink on the hot side first ti ensure hot water is getting to your dishwasher. Also make sure that the jet dry dispenser has jet dry in it. Hope this helps.
Jan 28, 2010 | LG LDF8812 Stainless Steel Built-in...
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Maytag Dishwasher Logo
222 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
