Question about Sony MDS-JE520 Mini Disc Player
Rec Error C13 after 10 sec recording - Sony MDS-JE520 Mini Disc Player
    Scholar:
    New Friend:
  • 134 Answers
It can't write to the disc for some reason, the disc may be locked and it can't write, it may be dirty, the table of contents may be corrupted or the disc is full to name a few reasons.
Posted on Jun 09, 2013
2 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Posted on Aug 03, 2009
Play back is ok.When I insert DVD +RW and press Record, error is shown
If you can tell me the error detail then I can definitely tell you the solution.
Corner Lights For BMW
Aug 17, 2012 | Mustek R100LB DVD Recorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Won't record on blank disc.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Sep 15, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Video stopy recording
I guess there's only so much room for videos on the internal memory... I did a full format, problem solved!
Sep 15, 2009 | Sanyo Xacti E1 Waterproof Camcorder
Sony minidisc MDS-JE530 c13 rec error
Aug 02, 2009 | Sony MDS-JE330 Mini Disc Player
Problem with Sony DSR 1500A won't record error flashes "Rec Inhib
dear,
the rec inhbit cable is faulty in this case ...
u need to replace that (holder assy,MIC.)
Regards
Jun 14, 2009 | Sony DSR-1500 Mini DV VCR
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Panasonic PV-DV203 REC
I have the same problem with mine and trying to figure what is the problem. Like you I've used it minimal times and it sat for a while and now I can't record anything. I hope some knows how to fix it without it costing an arm and a leg.
Dec 16, 2006 | Panasonic Palmcorder PV-DV203 Mini DV...
Sony MDS-JE520 Mini Disc Player Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
