Question about Cell Phones
My phone is on mute and shows a little headset diagram on the screen
  • 121 Answers
KINDLY CHANGE THE SETTINGS TO NORMAL PROFILE. THE MUTE AND HEADSET SYMBOL EXIBIT THE PHONE IS IN OUTDOOR PROFILE. THANKS
Posted on Dec 31, 2010
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
My whisper seems to be muted no one can hear me
Ensure that it isn't muted on headset and phone. Call us if you still have issues. Http://www.Motorola.com/contactus
Mark
Motorola Support
Aug 20, 2014 | Motorola Mobility Whisper Bluetooth...
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
Mar 16, 2011 | AT&T LUCENT / AVAYA CALLMASTER IV PHONE...
Inbound call on avaya - phone on mute and you hit the headset button by mistake = will it record that you disconnected the customer? I got fired for hanging up on customers with the Avaya hard phone and...
No, that will not disconnect the caller. BUT, if you hit the headset button again, it will.
If you hit the headset button, you need to hit the switch hook to regain the call....
Apr 08, 2010 | Avaya 4610SW IP Phone
Cs55 connects but has no sound on headset
The compatibility setting, in almost 100% of the cases, should be set to "1".  You can find it on the side of the base, it's a little turn wheel that will turn if you stick your thumbnail in it and twist.  I have seen one instance on the Cisco IP phones that requires the compatibility setting to be on 5, so try that as well.
If you have a lifter installed, make sure that the short telephone cable that comes out of the back of the headset's base unit is plugged into the handset port of the telephone (where the handset coily cord is normally plugged into).  You would then plug the handset coily cord into the front of the headset base unit.  Make sure you have that configuration, and try again.
Finally you can try a re-set.  To do this you should lift the headset off of the charging base, make sure the green light on the top of the base is off (the headset is off), and then do the following: 1. Hold down the mute button and the call answer button at the same time. (The mute button is the black little wheel on the top of the headset itself.  If you use the tip of your finger to push that straight in, it will mute the headset) 2.  Keep holding both buttons down until the green light below your thumb on the headset flashes for 2 consecutive series. 3.  Let go.  Wait about 20 seconds then try answering.
If this doesn't work, try a re-subscription: 1. Place the headset back on the charging base. 2. The two microphone volume adjust buttons on the back of the BASE unit should be pressed together.  This will start the red light and the yellow light blinking on the front of the base unit. 3. Hold the mute button down while the headset is still on the charging base.  Hold it down until the red light stops blinking. 4. Disconnect the power to the base so that the red light and yellow light turns off. 5. Plug the power back in after about 5 seconds of it being disconnected and make sure the red light on the front of the charging base is now solid and the yellow light is flashing. 6.  Pick up the headset and try again.
May 07, 2009 | Plantronics CS55 Wireless Headset
Remove the name that is showing on the phone.
To remove the name in the window, on handset press mute/menu key twice, press the #1 key once and press mute/menu 6 times.
Apr 03, 2009 | GE 25942GE2 Cordless Phone System
My headset was working fine (Plantronics CS50). Now I can use it to talk on my phone to office extensions but when I punch an outside line, their is a loud, very loud noice that prevents one from hearing...
The CS50 is not a phone and it is not specific to VoIP.  It does not transmit over the ehternet wiring in your office space.
Here is how to really "reboot" or as the manufacturer refers to it "perform a system reset" on your headset:
1. Lift the headset off of the charging base.  Make sure the headset is turned off.  The green light should not be lit on the charging base. 2. The mute button is on the black little wheel on the top of the headset.  If you push it straight down with the tip of your finger it will mute it.  Now, at the same time, push and hold the mute button with the call answer button.  You will see a green light on the headset flash quickly.  After 2 series of flashes, let go of both the call answer and the mute button. 3. Place the headset back on the charging cradle.  Leave it there for 30 seconds.  Lift it up and try it now.
Also make sure that the red light on the base is lit up.  This means there is power to the system.  If it's not, check the connection.
Jan 28, 2009 | Plantronics CS60 Professional Headset
People cannot hear me
I would think either your mute or your headset feature is activated. Mute button is obvious and the display should say mute. The headset also should have an icon on the display however you may have to turn it off in the MENU screen. .
j
Jan 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Verizon phone mute button
Talk about silly. This is the 3rd time typing the solution. (The Terms of Use link wiped it out too.) I had same problem by accidentally setting mute from bluetooth headset. If you have same situation, just turn volume up or down on headset. (Turning volume up or down on cellphone did not help me.) Good Luck,
BeenThere
Mar 26, 2008 | Cell Phones
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
