Question about DeLonghi 2507 Oil Filled Radiator Heater
What does the star mean on this radiator - DeLonghi 2507 Oil Filled Radiator Heater
Radiator need replacing
Remove radiator, take it to a radiator or sheetmetal shop and get them to solder the leak. Reinstall and add proper coolant.
Mar 18, 2014 | 2008 Yamaha Royal Star Venture
Cant locate radiator cap on yamaha royal star
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
The Venturers Yamaha Venture Technical Support Library
Yamaha Royal Star radiator cap location Google Search
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
YAMAHA XVZ1300A Owner Manual
Jan 14, 2014 | 1998 Yamaha Royal Star XVZ 1300 A
Locating radiator cap on 2008 yamaha royal star venture
yamaha royal star venture radiator cap location Google Search
How To Flush Coolant System 2004 2005 2006 R1 R1Videos com
http://www.starmotorcycles.com/assets/service/manuals/2006/LIT-11626-19-25%202006%20Venture_1193.pdf
Mar 28, 2013 | 1998 Yamaha Royal Star XVZ 1300 A
How to refill radiator in a royal star venture
Hi, Sid sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to fill radiator
Yamaha Fz6 How to Change Your Coolant
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Aug 10, 2012 | 2000 Yamaha Royal Star Venture
Cold engine light on, oil light flashing, bubbles of air on the engine oil stick?
Do not start the car. Tow it to a service centre and have it checked out as this sounds like amajor engine fault that may escalate if driven. If the car has an automatic transmission the drive wheels will need to be lifted or the car put on a truck to stop damage to the transmission when towing.
Please 3 or 4 stars only or dont vote as 1 or 2 stars are negative feedback
Aug 03, 2011 | 2000 Volkswagen Beetle
How to check thermostat on a 1999 silverado z71
When the truck is cold, with the engine off open the hood and search for for the upper radiator hose, look for a place on the hose to put your hand on it, a place that it's not close to any moving parts, (radiator's fan, and pulleys in front of the engine) now that you have fine a good spot on the hose to check the thermostat, go ahead star the engine and just wait while you keep your hand on the hose.
Ones the thermostat gets hot, it will open letting hot antifreeze flow into the radiator that's when your hand will feel this hot change on the radiator hose. It's a good time to take a look to your temperature gauge, it's too hot or too cold?
if the gauge moves higher than normally does, and you didn't feel a hot change on the hose, that means you have a bad thermostat that it's not opening on time or it's not opening at all,
if the gauge it's below than normally does, that means the thermostat it's open all the time
Nov 01, 2009 | 1999 Chevrolet Silverado 1500
How do I add coolant to my 2005 Yamaha Royal Star Tour Deluxe?
remove radiator cap slowly pour in 50/50 mixture while burping radiator hose. Better to do while running if possible
Oct 01, 2009 | 2005 Yamaha Royal Star Tour Deluxe
DeLonghi 2507 Oil Filled Radiator Heater Logo
49 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
