Question about General Electric WBSR3140GWW Top Load Washer
How do I take the agitator apart to clean it?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you do not really take the agitator out to clean. but if you wish to remove it.
1. you will remove the top dispenser from the agitator, then you may see a protective cap or you will see a screw, remove cap and or screw.
2. then remove agitator, it maybe hard to remove.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Thanks"
Take agitator apart
Can not take it apart but to remove it reach with both hands into the machine grip the agitator firmly at the bottom by getting both hands fingers under the bottom rim of the agitator. Give it a strong yank upwards (towards your body) to dislodge the agitator from the center shaft.
May 15, 2014 | Speed Queen AWS52NW Top Load Washer
The aggitator slips
t's supposed to be that way. If you could pull it up whenever you wanted, what would keep it from flying off during a wash cycle? The agitator is loosened from a bolt underneath the wash basket. Do not try that or you could damage the washer. Only a repairman or someone who has worked on washers should do that. Only if you had an article fall apart in the washer (a rug, feather pillow, etc.) should that area truly need cleaning. Call any GE repair shop. If this is under warranty and you have ( as shown ) the model #...........a repair inspector can fix this washer free. Have all your place of purchase documents with you. The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
May 01, 2011 | GE Washing Machines
How do i pull the agitator to clean inside it? its full of fabric softner and junk.
Depending on the agitator style, you'll have either a fabric softener dispenser or just a plastic cap on the top of your agitator. In both cases, you simply pull / pry those components off and you'll see a translucent cap further down with a rubber seal around it. Reach in and pop this cap off. Below it is a single bolt, threaded through the agitator to the agitator shaft. Remove the bolt with a rachet / socket / long extension or a speed wrench.
Now you simply pull the agitator straight up out of the machine. One word of caution... if you have a dual action agitator, there is a plastic gear / dog mechanism snapped inside. If you handle the agitator with care, you'll be fine. If not, this mechanism can come out and easily come apart- not a good scenario. It consists of 6 parts that you'd have to carefully put back together and reinsert.
Happy cleaning and good luck.
Jan 22, 2011 | Whirlpool LSR7333 Top Load Washer
My kenmore 80 series won't agitate it will spin but not wash clothes
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
I'd also verify that the Motor coupler is OK before taking apart the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools (socket set, pliers, screwdriver) you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Mar 30, 2010 | Kenmore Washing Machines
Removal of the agitator for cleaning
This video will show how to remove the agitator. You probably should replace the agitator dogs while you have it apart.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Feb 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Wouldn't agitate and how do i get it apart
If the agitator does not work, then depending on make, it could be your clutch or transmission or belt tension. Agitators are pushed on type(To remove pull up), but removing it will not solve problem, if agitator is not worn out.
Apr 27, 2009 | Washing Machines
Agitator not working - how do you take it apart - Kenmore 80 Series washer
Pop the top off the agitator. There is a slot for a flat screwdriver on the top side.
Remove the 7/16 bolt.
Pull the agitator apart.
Replace the agitator dogs inside the top part.
Parts about $5.00.at any appliance parts store.
Mar 14, 2009 | Kenmore 23012 Top Load Washer
The top part of agitator dose not move every much. Washer is Kenmore Heavy Duty Serial# CF3225915
It may be time to do a little agitator maintenance. Purchase yourself a set of agitator dogs (yes, they do exist) and replace them. The following link explains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
When you take the agitator apart, inspect and clean it as well. You can purchase dogs at searspartdirect.com or repairclinic.com. Do some comparative shopping for the best price. The average cost is less than $10. I hope this helps you. Let me know if you require additional assistance.
Aug 16, 2008 | Washing Machines
Fixing my vacuum cleaner
Check to make sure that your agitator still spins. (Agitator = brush). If your agitator still spins, it eliminates your belt and agitator as likely culprits. The last possible solution would be that your vacuum is clogged. The grinding sound might be a motor-related issue or could possibly mean your bearings are going out. Check the bearings of the agitator and the motor of the vacuum.
Accessing to the agitator and belt can be done by removing the bottom cover of your vacuum. There are 2 scews that are holding the bottom cover to the head of the unit. Remove these 2 scews and the bottom cover should snap off.
Mar 07, 2008 | Vacuums
General Electric WBSR3140GWW Top Load Washer Logo
172 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
