Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the cables are plugged up right. I made sure I was connected to the wireless network and the only way i get internet is if my labtop is hooked up instead of the desktop. How can I make my desktop connect to the router and allow the 2 laptops to go wirelessly.
    Problem Solver:
  • 11 Answers
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Posted on Dec 31, 2010
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys wireless for my desktop
Your Router might be locked on your laptop, try this,
1. Unplug the power cord from the wireless router
2. Wait 10 seconds.
3. Plug the router back in.
hope this helps
Nov 17, 2009 | Linksys Wireless-G Broadband Router
I have a cable modem that I know works since I'm connected to it directly right now. I'm trying to hook it up to an older Linksys wireless router and it is not recognizing it even after I reset it. The...
I use the same wireless G router that you have pictured. If you reset the router with the small reset button the security should be removed. If your laptop does not find the SSID which should be just LINKSYS after a reset make shure your technologys are the same. Is the wireless adapter on your laptop a G also? If you are using a N technology on your laptop it may not connect to or even see the G SSID
Aug 31, 2009 | Linksys Wireless-G Broadband Router
I lost my disc to my linksys wireless g router and i just bought a computer and im trying to hook my internet
if you go to the linksys web site they have a tool that hooks up your router for you. It is much better than the cd that came with the wireless G.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G not seeing internet connection
spacer335,
Who is your Internet service provider, and do you have cable or DSL? You said you have your PC, Xbox and DVR all hard-wired and working fine; are they currently able to get online while connected directly to the Linksys WRT54G? What devices are you trying to connect wirelessly to your Linksys WRT54G?
If you are currently getting Internet access let's check the wireless settings in your router.
Here are a few things you can do to verify your wireless settings in the Linksys WRT54G:
1. From your hard-wired PC, log into your Linksys WRT54G via the web-based interface. (Open Internet explorer and type 192.168.1.1) Note: this is the default IP address that comes on most Linksys routers.
If that doesn't work, verify your computers current IP address information by going to Start (or in Vista it's simply a windows icon), and selecting Run. Type CMD and hit Ok. Now type ipconfig and hit enter.
The default gateway information is the address of your router and should read something like 192.168.1.x.
Enter that address in Internet Explorer's address bar and hit Go.
2. If you connected successfully you should receive a username and password prompt, again the default username and password that comes with most Linksys devices is admin/admin, however it could be different if you've specified an alternate username/password. If you cannot remember the username/password, your only recourse is to perform a hard-reset of the device by using a small pin and holding the reset button on the back of the router.
3. Once you're in the router's web-based configuration there will be a section for "Wireless Settings" or "Wireless Configuration", or some derrevation. Depending on the version of firmware you have installed on the unit, it may be under Basic Setup or Advanced Setup.
You'll know you've located it when you have see options for SSID, Channel, Wireless Security/Encryption, WEP, WPA, etc.
This section will tell you the name of the signal your router broadcasts (also known as SSID). You can change this to whatever you like, in fact is reccommended you change to something unique so that you can easily identify your network when trying to connect with a laptop. You can also enable wireless security such as WEP or WPA, however for the purposes of troubleshooting let's leave encryption off for now. Once you've made the neccessary changes, select Save or Apply at the bottom of the page to save your changes.
4. Now, again since I don't know what you're attempting to connect wireless I will assume its a laptop with an intergrated wireless adpater, or possibly a USB or PCMCIA wireless adapter. Either way you should see your network (with the new name you've configured) in the list of avialable networks, do you see any networks listed? If the laptop has built-in wireless, is the WLAN switch enabled on the laptop? (Usually a small switch on the front or the side of the laptop indicating WLAN, or sometimes a function/fn key combination)
Hope this helps somewhat, give me some more information about what you're trying to connect wirelessly with and I'll see if I can help you out.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Laptop connecting but not my desktop
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
Feb 17, 2009 | Linksys Wireless-G Broadband Router
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
I have a laptop im trying to set up wireless i have everything i need but dont know how to do it .i also have linksys wireless router as well as a chip that goes to the taptop with a wireless linksys can...
Well Betty can you tell me what type of laptop do you have? Is it fairly new. Some laptops already have wireless cards installed in them.
However on the PC not the laptop...... before hooking anything up insert the software CD from linksys. This will advise you when to hook it up and should also give you some very good pictures on how it should look.
Now provided this goes as simple as it sounds lets reboot that laptop and see if it does not see the wirless router you just set up. If it doesnt I can try and assist you with plan B.
The goal here is to stay away from the difficulties of alot of settings. Good Luck and I will be watching for your response.
I wont see this until tommorrow evening as I am trveling to some sites and wont land in my motel until evening.
Bill
Apr 23, 2008 | Computers & Internet
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
119 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
