2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running
the battery will have 1% life left. If you turn c330 back on again, it
will flash screen for 3 seconds then die, even charging it at this
point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the
power home or car into Garmin c330. There is a tab in the front Garmin
gray frame of your screen. You must take like your fingernails and
under the logo "GARMIN" pull the whole gray plastic frame off.
Underneath the plastic frame to the right hand side. There is a "RESET"
button. Make sure power is plugged in while hitting reset. Your battery
should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009
"My
Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It
is still connected to the car charger. Will a battery replacement fix
this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
