Question about B&K Drinking Water Faucet By Muellerbk 120004
I am experienced in plumbing installation and have just installed a B&K model 120004 drinking water faucet in my kitchen. The faucet is supposed to have a "constant on" position but it does not work. What is wrong? Jim
  • 111 Answers
Mine flips up for constant .
Posted on Jan 12, 2011
How to tighten a Moen Anabelle CA87003SRS single handle kitchen faucet to sink?
Shut off the water
Clean and dry the area around the faucet.
(from the bottom)
Disconnect/remove the faucet (clean or replace gasket).
Clean the hole completely & apply desired sealant
Positon the faucet in the hole & TIGHTEN (firmly).
Reconnect water lines & restore water supply.
(do NOT over-tighten).
Place clean "printer" paper under each wall valve & supervise
for several days to assure no DROPS are leaving wet marks on the paper.
Be proud.
Carnac the Magnificent
Mar 21, 2017 | Moen Plumbing
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
http://www.doityourself.com/forum/plumbing-piping/310875-low-water-pressure-new-kitchen-faucet.html#b
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
When switched to filtered water on my kitchen faucet water comes out of both sides like the switch isn't working brand new filter on 1year old unit?
Sorry, these thing are often more trouble than they are worth. Without naming names, even the best of the best have seal and valve issues over an unreasonably short period of time. While they are quick and easy to install compared to a plumbed in model, they eventually leak from somewhere, the faucet, the filter cover, or, like yours, the cut-over valve.
You can, keep spending money on replacements, have a dedicated filter plumbed in, or resort to bottled water, all of which run the cost of purified water up beyond the price of tap water.
May 21, 2016 | Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Elkay kitchen faucet model lk7124 replace stem
    ELKAY ' Strainers, Fittings + Other Accessories for the Home
    www.elkay.com/strainers-fittings-other
    Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
    ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
    www.elkay.com/
    Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
    [PDF]SPECIFICATIONS
    aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
    LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-Arc® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
    Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
    www.amazon.com > ... > Faucet Parts
    Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
    Elkay A51947R Replacement Diacore Cartridge with Brown ...
    www.amazon.com/Elkay...Replacement.../B0033UX8...
    Amazon.com, Inc
    Jan 14, 2016 | Elkay Plumbing
    Installed a new pressure fitting and no water is coming out
    What is a pressure fitting? Is this a single handle or dual handle faucet, kitchen or bathroom? which model? Did you remove the aerator and make sure it is clean (standard plumbing procedure after playing with the pipes) If the supplies connected to 1/4 inch or 3/8 inch lines did you use two wrenches to prevent twisting the tubing?
    Nov 03, 2013 | Price Pfister Plumbing
    I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
    Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
    Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
    Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
    Cannot remove Kohler ceramic valve
    is this a single handle faucet. If not the part goes in under the handle
    Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
    Drains Technical Question
    Plumbing codes call for a gap between potable water and a drain. This usually looks like the distance between the faucet and the top of the sink or bathtub (one inch or more). Without the "gap", waste water could siphon back into the drinking supply. This "does" happen in situations where a city main is shut off causing a drain-down of the system with plumbing that has been done improperly. Sometimes it is a hose left in a mud puddle, or maybe a hose lying in bleach water. People have died this way. The plumbing code helps protect the general public from these dangers. Current improvements include antisiphon faucets for garden hoses, the air gap for the dishwasher, proper installation of water heater T&P relief drains, and backflow preventers for irrigation systems.
    Aug 27, 2008 | Elkay LK58 Drain
    B&K Drinking Water Faucet By Muellerbk 120004 Logo
    77 people viewed this question
    Top B&K Plumbing Experts
    Tom Chichester
    Bill Boyd
    Daryl Gleaton
    Are you a B&K Plumbing Expert? Answer questions, earn points and help others
