Question about Husqvarna Sewing Machines
Good morning, My machine is about 30 years old. The reverse button is sticking. So I opened the back up and there is a little spring which attaches to something (?) but has come off. (I think) Any ideas or suggestions would be very much appreciated. Thanks Maggie
    Genius:
  • 1,788 Answers
Hi, Happy New Year
Is your dealer close to your home? Sometimes the salespeople are able to help you for no charge. I know the girls who work at my dealer (JoAnn's fabrics, Viking center) are super good about helping anybody who has a Husqvarna machine. I would be afraid to have someone else monkey with it for fear they would mess it up more. Plus, you have a great machine and it probably is due for a little love and attention, like a tuneup anyway, if they have to send it out for service. It is definately worth fixing. I do not have a schematic of your machine so unless someone has one, or are familiar with the model they really cannot advise you. Good Luck.
Posted on Dec 31, 2010
When the machine is on doesn't stop.
Soraia, sewing machine pedal may be sticking, inspect it while unplugged to see if the spring loaded action and the button under pedal is moving freely, if not try a few drops of oil on pedal hinge and button. If all appears to be good, have pedal repaired/replaced as it is probably an internal transformer issue inside the pedal.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.thesewingforum.co.uk/showthread.php?t=29533
Old Singer foot pedal problem
How to Repair the Foot Control on Your Sewing Machine
Apr 26, 2016 | Sewing Machines
Singer Quantum CXL: After I use the reverse button and release it, the machine does not go back to stitching forward. It stays "stuck" in reverse until I turn it off and back on again. :-( ?
the reverse mechanism is not releasing to go back to its normal forward position. if you do not have pressure on the reverse button and it feels like there is some slack with no tension on the button, the mechanism has not returned to the forward position. there may be a spring that has the end broken off to keep tension on the reverse mechanism,, it would be a good idea to have the machine checked to see what the problem is.
Jun 02, 2015 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
My reverse stitch doesn't work?
There is a rocker inside the machine the rocks back and forth with the operation of the reverse button. It will stick if it is not serviced regularly. If you have the machine serviced every 2 to 3 years, by someone who knows the machine, everything should work fine for many years to come. Not servicing a sewing machine is something like not servicing an automobile. It will run fine well beyond the recommended service time but when it stops, you will need to spend a lot more money than what you would for a standard oil change.
Feb 13, 2010 | Husqvarna Sewing Machines
Will not sew in reverse.
sometimes it is the spring, open the machine up and take a look at the spring, it may be broken or stretched. It should be located right where the reverse lever is, inside.
Jun 18, 2009 | Kenmore 16622 Mechanical Sewing Machine
Reverse doesn't work
Remove the base cover and follow the lever you mentioned that has "little movement" to a collar around the shaft......or similar if not Janome.........use WD40 or similar penetrating lube between the shaft/collar, and move by hand rapidly a few times to introduce the lube between sticking points.
Use paper tissue around the area to absorb overspray and excess.
Try the reverse lever again,,,,sometimes it can take several applications and some persistance, but I've only had a few that failed to respond.....some take several days and quite a bit of 'jiggling'. A good first sign is a long, slow, reluctant movement soon after spraying.
Best long term solution is regular use and keep dry and free of dust and lint......old oil and dust form a glue like fluid, and any slight corrosion left too long will seize the parts, where regular use breaks the bonding. Silica Gel dessicant (sachets found in Vitamin Jars) is a good moisture deterrent if you keep it in the case/cover with machine,,,,,,,,,,if you don't have a cover, make one !! ( or use an old  teatowel)
If you mention your make and model it generally makes it easier to be specific, with this question, you are posting generic, but mechanisms vary from manufacturer and model.
Best of....
www.bargainbox.com.au
Nov 19, 2008 | Sewing Machines
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
